A Look Back at the U.S. Department of Energy's Aquatic Species Program ? Biodiesel from Algae, 1998. ,
Microalgae as biodiesel & biomass feedstocks: Review & analysis of the biochemistry, energetics & economics, Energy & Environmental Science, vol.102, issue.25, pp.554-590, 2010. ,
DOI : 10.1007/s12155???009???9046-x
Anaerobic digestion of microalgae as a necessary step to make microalgal biodiesel sustainable, Biotechnology Advances, vol.27, issue.4, pp.409-416, 2009. ,
DOI : 10.1016/j.biotechadv.2009.03.001
URL : https://hal.archives-ouvertes.fr/hal-00854465
An Outlook on Microalgal Biofuels, Science, vol.329, issue.5993, pp.796-799, 2010. ,
DOI : 10.1126/science.1189003
Biodiversity and application of microalgae, Journal of Industrial Microbiology & Biotechnology, vol.87, issue.5-6, pp.477-489, 1996. ,
DOI : 10.1007/BF01574779
DIEL VARIATIONS OF CARBOHYDRATES AND NEUTRAL LIPIDS IN NITROGEN-SUFFICIENT AND NITROGEN-STARVED CYCLOSTAT CULTURES OF ISOCHRYSIS SP.1, Journal of Phycology, vol.39, issue.9, pp.966-975, 2012. ,
DOI : 10.1111/j.1529-8817.2012.01177.x
Dynamic model of phytoplankton growth and acclimation:responses of the balanced growth rate and the chlorophyll a:carbon ratio to light, nutrient-limitation and temperature, Marine Ecology Progress Series, vol.148, pp.187-200, 1997. ,
DOI : 10.3354/meps148187
Hurdles and challenges for modelling and control of microalgae for CO2 mitigation and biofuel production, Journal of Process Control, vol.21, issue.10, pp.1378-1389, 2011. ,
DOI : 10.1016/j.jprocont.2011.07.012
URL : https://hal.archives-ouvertes.fr/hal-00848385
Photosynthesis???Irradiance Response at Physiological Level: a Mechanistic Model, Journal of Theoretical Biology, vol.213, issue.2, pp.121-127, 2001. ,
DOI : 10.1006/jtbi.2001.2413
25 Years of Algal Growth Kinetics A Personal View, Botanica Marina, vol.26, issue.3, pp.99-112, 1983. ,
DOI : 10.1515/botm.1983.26.3.99
Dynamic behaviour of a model for photosynthesis and photoinhibition, Ecological Modelling, vol.69, issue.1-2, pp.113-133, 1993. ,
DOI : 10.1016/0304-3800(93)90052-T
Aquatic Photosynthesis, 2007. ,
DOI : 10.1515/9781400849727
Coupling and uncoupling between nitrate uptake and growth rate in Prorocentrum minimum (Dinophyceae) under different frequencies of pulsed nitrate supply, Marine Ecology Progress Series, vol.72, pp.261-269, 1991. ,
DOI : 10.3354/meps072261
Vitamin B12 and Marine Ecology. IV. The Kinetics of Uptake, Growth and Inhibition in Monochrysis Lutheri, Journal of the Marine Biological Association of the United Kingdom, vol.33, issue.03, pp.689-733, 1968. ,
DOI : 10.1038/191868a0
The attractiveness of the droop equations, Mathematical Biosciences, vol.111, issue.2, pp.261-278, 1992. ,
DOI : 10.1016/0025-5564(92)90074-7
Transient behavior of biological loop models with application to the Droop model, Mathematical Biosciences, vol.127, issue.1, pp.19-43, 1995. ,
DOI : 10.1016/0025-5564(94)00040-7
Experiment selection for the discrimination of semi-quantitative models of dynamical systems, Artificial Intelligence, vol.170, issue.4-5, pp.472-506, 2006. ,
DOI : 10.1016/j.artint.2005.11.001
URL : https://hal.archives-ouvertes.fr/inria-00071639
The steady states of continuous cultures with low rates of medium renewal per cell, Journal of Experimental Marine Biology and Ecology, vol.178, issue.1, pp.1-15, 1994. ,
DOI : 10.1016/0022-0981(94)90221-6
Non-linear qualitative signal processing for biological systems: application to the algal growth in bioreactors, Mathematical Biosciences, vol.157, issue.1-2, pp.357-372, 1999. ,
DOI : 10.1016/S0025-5564(98)10091-3
New cell-based model of photosynthesis and photo-acclimation: accumulation and mobilisation of energy reserves in phytoplankton, Marine Ecology Progress Series, vol.383, pp.53-71, 2009. ,
DOI : 10.3354/meps07961
Interaction between time scales in microalgae based processes, 2012 20th Mediterranean Conference on Control & Automation (MED), 2012. ,
DOI : 10.1109/MED.2012.6265697
URL : https://hal.archives-ouvertes.fr/hal-00848416
PHOTOACCLIMATION OF PHOTOSYNTHESIS IRRADIANCE RESPONSE CURVES AND PHOTOSYNTHETIC PIGMENTS IN MICROALGAE AND CYANOBACTERIA1, Journal of Phycology, vol.38, issue.1, pp.17-38, 2002. ,
DOI : 10.1046/j.1529-8817.2002.00094.x
ADAPTATION OF UNICELLULAR ALGAE TO IRRADIANCE: AN ANALYSIS OF STRATEGIES, New Phytologist, vol.16, issue.1, pp.157-191, 1983. ,
DOI : 10.1016/0304-4173(79)90008-9
Light--Shade Adaptation : TWO STRATEGIES IN MARINE PHYTOPLANKTON, PLANT PHYSIOLOGY, vol.66, issue.4, pp.592-595, 1980. ,
DOI : 10.1104/pp.66.4.592
GAMS-BARON Manual (ver. 11.0.2), 2012. ,
Chlorophyll a Fluorescence in Aquatic Sciences: Methods and Applications, 2010. ,
