Compressed Sensing Information Theory, IEEE Transactions on, vol.52, issue.4, pp.1289-1306, 2006. ,
Sensor-array calibration using a maximumlikelihood approach Antennas and Propagation, IEEE Transactions on, vol.44, issue.6, pp.827-835, 1996. ,
Blind calibration of sensor networks, Information Processing in Sensor Networks 6th International Symposium on, pp.79-88, 2007. ,
Calibrating Nonlinear Mobile Sensors, 2008 5th Annual IEEE Communications Society Conference on Sensor, Mesh and Ad Hoc Communications and Networks, pp.533-541, 2008. ,
DOI : 10.1109/SAHCN.2008.70
Robustly Stable Signal Recovery in Compressed Sensing With Structured Matrix Perturbation, IEEE Transactions on Signal Processing, vol.60, issue.9, pp.4658-4671, 2012. ,
DOI : 10.1109/TSP.2012.2201152
Compressed sensing for acoustic response reconstruction: Interpolation of the early part, 2011 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.225-228, 2011. ,
DOI : 10.1109/ASPAA.2011.6082298
URL : https://hal.archives-ouvertes.fr/hal-00766979
Stable signal recovery from incomplete and inaccurate measurements, Communications on Pure and Applied Mathematics, vol.7, issue.8, pp.1207-1223, 2006. ,
DOI : 10.1002/cpa.20124
General deviants: An analysis of perturbations in compressed sensing Selected Topics in Signal Processing, IEEE Journal, vol.4, issue.2, pp.342-349, 2010. ,
Joint recovery of sparse signals and parameter perturbations with parameterized measurement models, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing ,
DOI : 10.1109/ICASSP.2013.6638796
Autocalibrated signal reconstruction from linear measurements using adaptive GAMP, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing ,
DOI : 10.1109/ICASSP.2013.6638801
URL : http://bigwww.epfl.ch/publications/kamilov1301.pdf
Blind Calibration in Compressed Sensing Using Message Passing Algorithms, 2013. ,
An autofocus technique for high-resolution inverse synthetic aperture radar imagery Geoscience and Remote Sensing, IEEE Transactions on, vol.52, issue.10, pp.6392-6403, 2014. ,
Blind calibration for compressed sensing by convex optimization, 2012 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.2713-2716, 2012. ,
DOI : 10.1109/ICASSP.2012.6288477
URL : https://hal.archives-ouvertes.fr/hal-00658579
Observed universality of phase transitions in high-dimensional geometry, with implications for modern data analysis and signal processing, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.22, issue.27, pp.4273-93, 1906. ,
DOI : 10.1073/pnas.0502258102
Distributed Optimization and Statistical Learning via the Alternating Direction Method of Multipliers, Machine Learning, pp.1-122, 2011. ,
DOI : 10.1561/2200000016
PhaseLift: Exact and Stable Signal Recovery from Magnitude Measurements via Convex Programming, Communications on Pure and Applied Mathematics, vol.38, issue.5, 2011. ,
DOI : 10.1002/cpa.21432
On Signal Reconstruction without Noisy Phase, Tech. Rep, 2004. ,
On signal reconstruction without phase, Applied and Computational Harmonic Analysis, vol.20, issue.3, pp.345-356, 2006. ,
DOI : 10.1016/j.acha.2005.07.001
Fast algorithms for signal reconstruction without phase, Wavelets XII, pp.67-78, 2007. ,
DOI : 10.1117/12.731117
Compressive Phase Retrieval From Squared Output Measurements Via Semidefinite Programming*, IFAC Proceedings Volumes, vol.45, issue.16, 2011. ,
DOI : 10.3182/20120711-3-BE-2027.00415
URL : http://arxiv.org/abs/1111.6323
CPRL-An Extension of Compressive Sensing to the Phase Retrieval Problem, Neural Information Processing Systems (NIPS), 2012. ,
Quadratic Basis Pursuit, Signal Processing with Adaptive Sparse Structured Representations (SPARS) Workshop, 2013. ,
Blind Phase Calibration in Sparse Recovery, 21st European Conference on Signal Processing (EUSIPCO), 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00813421
Balancing Sparsity and Rank Constraints in Quadratic Basis Pursuit ArXiv e-prints, 2014. ,
Sparse Signal Recovery from Quadratic Measurements via Convex Programming, SIAM Journal on Mathematical Analysis, vol.45, issue.5, pp.1-15, 2012. ,
DOI : 10.1137/120893707
