Estimation of neutral lipid and carbohydrate quotas in microalgae using adaptive interval observers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioprocess and Biosystems Engineering Année : 2014
Under stress conditions, microalgae are known to accumulate large amounts of neutral lipids and carbohydrates, which can be used for biofuel production. However, on-line measurement of microalgal biochemical composition is a difficult task which makes the microalgal process rather difficult to manage. In this paper, we propose a so called adaptive interval observer for the on-line estimation of neutral lipid and carbohydrate quotas in microalgae. The observer is based on a change of coordinates that involves a time-varying gain. We introduce dynamics for the gain, whose trajectory converges toward a predefined optimal value (which maximizes the convergence rate of the observer). The observer performance is illustrated with experimental data of Isochrysis sp. cultures under nitrogen limitations and day-night cycle. The proposed observer design appears to be a suitable robust estimation technique.
BBE-obs_lipid-v5_post-print.pdf (440.56 Ko) Télécharger le fichier
hal-00854476 , version 1 (27-08-2013)
Francis Mairet, Marcelo Moisan, Olivier Bernard. Estimation of neutral lipid and carbohydrate quotas in microalgae using adaptive interval observers. Bioprocess and Biosystems Engineering, 2014, 37 (1), pp.51-61. ⟨10.1007/s00449-013-0913-7⟩. ⟨hal-00854476⟩
278 Consultations
305 Téléchargements
