New interface
Conference papers
Identification of Wiener system with monotonous nonlinearity
Abstract : A Wiener system is composed of a linear dynamic subsystem followed by a static nonlinearity. It is well known in the literature that the identification of the linear subsystem of a Wiener system can be separated from that of the output nonlinearity, if the input signal is a Gaussian noise. In order to deal with the non Gaussian input case, two new algorithms are proposed in this paper for direct identification of the linear subsystem, regardless of any parametrization of the output nonlinearity. The essential assumption required in this paper is the strict monotonousness of the output nonlinearity.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00854858
Contributor : Qinghua Zhang Connect in order to contact the contributor
Submitted on : Wednesday, August 28, 2013 - 11:41:27 AM
Last modification on : Friday, January 21, 2022 - 3:14:56 AM
Identifiers
Collections
Citation
Qinghua Zhang, Anatoli B. Juditsky, Lennart Ljung. Identification of Wiener system with monotonous nonlinearity. 14th IFAC Symposium on System Identification (SYSID), Mar 2006, Newcastle, Australia. pp.166-171, ⟨10.3182/20060329-3-AU-2901.00020⟩. ⟨hal-00854858⟩
Share
Metrics
Record views
79
