BugMaps-Granger: A Tool for Causality Analysis between Source Code Metrics and Bugs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Despite the increasing number of bug analysis tools for exploring bugs in software systems, there are no tools supporting the investigation of causality relationships between internal quality metrics and bugs. In this paper, we propose an extension of the BugMaps tool called BugMaps-Granger that allows the analysis of source code properties that caused bugs. For this purpose, we relied on Granger Causality Test to evaluate whether past changes to a given time series of source code metrics can be used to forecast changes in a time series of defects. Our tool extracts source code versions from version control platforms, generates source code metrics and defects time series, computes Granger, and provides interactive visualizations for causal analysis of bugs. We also provide a case study in order to evaluate the tool.
Mots clés
2013_cbsoft_tools_bugmapsgranger.pdf (248.92 Ko) Télécharger le fichier
hal-00854883 , version 1 (28-08-2013)
  • HAL Id : hal-00854883 , version 1
Cesar Couto, Pedro Pires, Marco Tulio Valente, Roberto Bigonha, Andre Hora, et al.. BugMaps-Granger: A Tool for Causality Analysis between Source Code Metrics and Bugs. Brazilian Conference on Software: Theory and Practice (CBSoft'13), Sep 2013, Brasilia, Brazil. ⟨hal-00854883⟩
254 Consultations
167 Téléchargements
