A method for actuator fault diagnosis with robustness to sensor distortion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Actuator fault diagnosis is often studied under strong assumptions on available sensors: typically it is assumed that either the sensors are fault-free or there is a sufficient redundancy among the sensors. The purpose of this paper is to propose a new method for actuator fault diagnosis which is robust to sensor distortion. It does not require sensor redundancy to compensate sensor distortion. The essential assumption is that sensor distortions are strictly monotonous. Despite the nonlinear and unknown nature of distortions, such sensors still provide useful information for fault diagnosis. A numerical example is provided to illustrate the efficiency of the proposed method.
Automatique
hal-00854915 , version 1 (28-08-2013)
Qinghua Zhang. A method for actuator fault diagnosis with robustness to sensor distortion. 6th IFAC Symposium on Fault Detection, Supervision and Safety of Technical Processes (SAFEPROCESS), Aug 2006, Beijing, China. pp.1033-1038, ⟨10.3182/20060829-4-CN-2909.00172⟩. ⟨hal-00854915⟩
Collections
INRIA INRIA2
89 Consultations
0 Téléchargements
