Control of cleft glutamate concentration and glutamate spill-out by perisynaptic glia: uptake and diffusion barriers. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS ONE Année : 2013
Most glutamatergic synapses in the mammalian central nervous system are covered by thin astroglial processes that exert a dual action on synaptically released glutamate: they form physical barriers that oppose diffusion and they carry specific transporters that remove glutamate from the extracellular space. The present study was undertaken to investigate the dual action of glia by means of computer simulation. A realistic synapse model based on electron microscope data and Monte Carlo algorithms were used for this purpose. Results show (1) that physical obstacles formed by glial processes delay glutamate exit from the cleft and (2) that this effect is efficiently counteracted by glutamate uptake. Thus, depending on transporter densities, the presence of perisynaptic glia may result in increased or decreased glutamate transient in the synaptic cleft. Changes in temporal profiles of cleft glutamate concentration induced by glia differentially impact the response of the various synaptic and perisynaptic receptor subtypes. In particular, GluN2B- and GluN2C-NMDA receptor responses are strongly modified while GluN2A-NMDA receptor responses are almost unaffected. Thus, variations in glial transporter expression may allow differential tuning of NMDA receptors according to their subunit composition. In addition, simulation data suggest that the sink effect generated by transporters accumulation in the vicinity of the release site is the main mechanism limiting glutamate spill-out. Physical obstacles formed by glial processes play a comparatively minor role.
journal.pone.0070791.PDF (3.54 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-00855024 , version 1 (30-09-2016)
Jean-Pierre Kessler. Control of cleft glutamate concentration and glutamate spill-out by perisynaptic glia: uptake and diffusion barriers.. PLoS ONE, 2013, 8 (8), pp.e70791. ⟨10.1371/journal.pone.0070791⟩. ⟨hal-00855024⟩
150 Consultations
60 Téléchargements
