SPREPI: Selective Prediction and REplay for predicated Instructions
ARM ISA-based processors are no longer low-cost low-power processors. Nowadays ARM ISA based processor manufacturers are struggling to implement medium-end to high-end processor cores, and this implies implementing a state-of-the-art out-of-order execution engine. Unfortunately providing efficient out-of-order execution on legacy ARM codes may be quite challenging due to predicated instructions. In this paper, we propose a new hardware solution, Selective Prediction and REplay for Predicated Instructions (SPREPI), to provide efficient out-of-order execution of codes featuring predicated instructions. Predicting the predicated instructions addresses the so-called multiple definition problem. Predicated instructions are predicted using either a global branch-and-predicate history predictor or a global history predictor. But systematic usage of predicate prediction sometimes impairs the performance dramatically. Efficient filters are proposed to disable predicate prediction uses when they are likely to be counter-productive. Moreover predicate misprediction penalty can be as high as the branch mispenalty. To reduce this penalty we introduce a specific selective replay hardware component targeting mispredicted predicated instructions. SPREPI is shown to allow high out-order execution performance on ARM codes generated even with a compiler applying if-conversion only to very short branches. Moreover since SPREPI predicts most of the predicated instructions, a relatively inefficient hardware solution is sufficient for executing the few predicated instructions on which prediction is not used.
Les processeurs basés sur le jeu d'instructions ARM ne sont plus seulement des processeurs à petit budget et à faible consommation. De nos jours, les concepteurs de processeurs ARM cherchent à créer des coeurs d'exécution à performances moyennes voire hautes, impliquant l'implémentation de l'état de l'art d'un moteur d'exécution dans le désordre. Cependant, permettre une exécution dans le désordre efficace peut se révéler difficle sur les codes ARM anciens à cause des instructions prédiquées. Dans cet article, nous proposons une nouvelle solution matérielle, la prédiction et le rejeu sélectif pour les instructions prédiquées (SPREPI) pour permettre une exécution efficace de codes avec des instructions prédiquées. Prédire les instructions prédiquées permet de résoudre le problème appelé le problème des définitions multiples. Elles sont prédites en utilisant soit un prédicteur à historique global des branchements et prédicats soit un prédicteur à historique des branchements seul. Cependant, l'utilisation systématique de la prédiction entraîne parfois des pertes de performances dramatiques. Des filtres efficaces sont proposés pour désactiver l'utilisation de la prédiction quand il y a des chances qu'elle soit contre-productive. De plus, une mauvaise prédiction de prédicat peut être aussi coûteuse qu'une mauvaise prédiction de branchement. Pour réduire ce coût, nous proposons un mécanisme matériel spécifique de rejeu sélectif ciblant les instructions prédiquées mal prédites. Nous montrons que SPREPI permet une exécution dans le désordre performante sur du code ARM, même lorsque le compilateur n'applique la transformation de if-conversion qu'aux branchements très courts. De plus, comme SPREPI prédit la plupart des instructions prédiquées, une solution matérielle relativement inefficace suffit à exécuter les quelques instructions prédiquées pour lesquelles la prédiction n'est pas utilisée.
