PLAZA : Case-based Reasoning : Foundational Issues, Methodological Variations, and System Approaches. AI Communications, pp.39-59, 1994. ,
Abstract, The Journal of Symbolic Logic, vol.48, issue.02, pp.510-530, 1985. ,
DOI : 10.1080/00048408412341331
NOTEBAERT : LP_SOLVE a Mixed Integer Linear Programming (MILP) solver, 2010. ,
Adaptation of ingredient quantities and of textual preparations, 18h International Conference on Case-Based Reasoning -ICCBR 2010Computer Cooking Contest" Workshop Proceedings, 2010. ,
Adapter des cas en utilisant un opérateur de révision ou des règles, L. CHOLVY et S. KONIECZNY, éditeurs : Journée Intelligence Artificielle Fondamentale, 2010. ,
An Algorithm for Adapting Cases Represented in ALC, 22th International Joint Conference on Artificial Intelligence (IJCAI- 2011), 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00584103
Belief revision-based casebased reasoning, Proceedings of the ECAI-2012 Workshop SAMAI : Similarity and Analogy-based Methods in AI, pp.33-39 ,
URL : https://hal.archives-ouvertes.fr/hal-00763220
Diverse Plan Generation by Plan Adaptation and by First-Principles Planning: A Comparative Study, LNCS, vol.7466, pp.32-46, 2012. ,
DOI : 10.1007/978-3-642-32986-9_5
A Syntactical Approach to Qualitative Constraint Networks Merging, Logic for Programming, Artificial Intelligence, and Reasoning (LPAR), pp.233-247, 2010. ,
DOI : 10.1007/978-3-642-16242-8_17
URL : https://hal.archives-ouvertes.fr/hal-00866877
Investigations into a theory of knowledge base revision : Preliminary report, Proceedings of the Seventh National Conference on Artificial Intelligence (AAAI-88), pp.475-479, 1988. ,
Adaptation de cas spatiaux et temporels, 20ème atelier Français de Raisonnement à Partir de Cas, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00712982
Adapting Spatial and Temporal Cases, éditeurs : International Conference for Case-Based Reasoning, pp.77-91, 2012. ,
DOI : 10.1007/978-3-642-32986-9_8
URL : https://hal.archives-ouvertes.fr/hal-00735231
Text Adaptation Using Formal Concept Analysis, Proceedings of the 18th International Conference on Case-Based Reasoning (ICCBR-2010), pp.96-110, 2010. ,
DOI : 10.1007/978-3-642-14274-1_9
URL : https://hal.archives-ouvertes.fr/hal-00509030
Propositional knowledge base revision and minimal change, Artificial Intelligence, vol.52, issue.3, pp.263-294, 1991. ,
DOI : 10.1016/0004-3702(91)90069-V
Amalgam-Based Reuse for Multiagent Case-Based Reasoning, 19th International Conference on Case Based Reasoning -ICCBR'2011, pp.122-136, 2011. ,
DOI : 10.1007/978-3-642-23291-6_11
Towards Case-Based Adaptation of Workflows, Proceedings of the 7th International Conference on Case-Based Reasoning, pp.421-435, 2007. ,
DOI : 10.1007/978-3-642-14274-1_31
A spatial logic based on regions and connection, International Conference on Principles of Knowledge Representation and Reasoning (KR), pp.165-176, 1992. ,
éditeurs : Case-Based Reasoning Technologies. From Foundations to Applications, LNCS 1400, issue.1, pp.1-15, 1998. ,
SCHANK : Inside Case- Based Reasoning, 1989. ,
Opponent Type Adaptation for Case-Based Strategies in Adversarial Games ,
DOI : 10.1007/978-3-642-32986-9_27
éditeurs : Case- Based Reasoning Research and Development (IC- CBR 2012, LNCS, vol.7466, pp.357-368, 2012. ,
From Inconsistency to Consistency : Knowledge Base Revision by Tableaux Opening Advances in Artificial Intelligence IBERAMIA 2010, LNCS, vol.6433, pp.120-132, 2010. ,
