New interface
Reports (Research report)
Heterogeneity Considered Harmful to Algorithm Designers
Olivier Beaumont 1 Vincent Boudet 1 Arnaud Legrand 1 Fabrice Rastello 1 Yves Robert 1
1 REMAP - Regularity and massive parallel computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : In this paper, we deal with algorithmic issues on heterogeneous platforms. We show that static scheduling and load-balancing strategies are absolutely needed to achieve good performances, in contrast to situation for homogeneous parallel machines where dynamic schemes often turn out to be very satisfactory. However, we also show that static strategies targeted to heterogeneous platforms are difficult to design and implement: intuitively, data distribution must obey a much more refined model than standard block-cyclic distributions to equally balance the load between processors of different speeds. Technically, we state several NP-completeness results that demonstrate the intrinsic difficulty of static load-balancing on heterogeneous platforms.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-00856642
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Monday, September 2, 2013 - 10:21:56 AM
Last modification on : Wednesday, October 26, 2022 - 8:16:19 AM
Identifiers
  • HAL Id : hal-00856642, version 1
Citation
Olivier Beaumont, Vincent Boudet, Arnaud Legrand, Fabrice Rastello, Yves Robert. Heterogeneity Considered Harmful to Algorithm Designers. [Research Report] 2000-24, 2000. ⟨hal-00856642⟩
Share
Metrics
Record views
57
