Matrix-matrix multiplication on heterogeneous platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
Vincent Boudet
Fabrice Rastello
Yves Robert
In this paper, we address the issue of implementing matrix-matrix multiplication on heterogeneous platforms. We target two different classes of heterogeneous computing resources: heterogeneous networks of workstations, and collections of heterogeneous clusters. Intuitively, the problem is to load balance the work with different-speed resources while minimizing the communication volume. We formally state this problem and prove its NP-completeness. Next we introduce a (polynomial) column-based heuristic, which turns out to be very satisfactory: we derive a theoretical performance guarantee for the heuristic, and we assess its practical usefulness through MPI experiments
Fichier non déposé
hal-00856648 , version 1 (02-09-2013)
Olivier Beaumont, Vincent Boudet, Fabrice Rastello, Yves Robert. Matrix-matrix multiplication on heterogeneous platforms. 2000 International Conference on Parallel Processing (ICPP'2000), 2000, Toronto, Canada. pp.289-298, ⟨10.1109/ICPP.2000.876144⟩. ⟨hal-00856648⟩
67 Consultations
0 Téléchargements
