Design of Optimal Experiments for Parameter Estimation of Microalgae Growth Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mathematical models are expected to play a pivotal role for driving microalgal production towards a profitable process of renewable energy generation. To render models of microalgae growth useful tools for prediction and process optimization, reliable parameters need to be provided. This reliability implies a careful design of experiments that can be exploited for parameter estimation. In this paper, we provide guidelines for the design of experiments with high informative content that allows an accurate parameter estimation. We study a real experimental device devoted to evaluate the effect of temperature and light on microalgae growth. On the basis of a mathematical model of the experimental system, the optimal experiment design problem was solved as an optimal control problem. E-optimal experiments were obtained by using two discretization approaches namely sequential and simultaneous. The results showed that an adequate parameterization of the experimental inputs provided optimal solutions very close to those provided by the simultaneous discretization. Simulation results showed the relevance of determining optimal experimental inputs for achieving an accurate parameter estimation.
2013_Munoz-Tamayo_OED_Algae_CAB.pdf (336.85 Ko) Télécharger le fichier
hal-00856749 , version 1 (02-09-2013)
  • HAL Id : hal-00856749 , version 1
  • PRODINRA : 281445
Rafael Munoz Tamayo, Pierre Martinon, Gaël Bougaran, Francis Mairet, Olivier Bernard. Design of Optimal Experiments for Parameter Estimation of Microalgae Growth Models. International Symposium on Computer Applications to Biotechnology (CAB 2013), Dec 2013, Mumbai, India. ⟨hal-00856749⟩
1111 Consultations
424 Téléchargements
