Journal articles
On the Optimality of Allen and Kennedy's Algorithm for Parallelism Extraction in Nested Loops
Alain Darte 1, * Frédéric Vivien 1
* Corresponding author
1 REMAP - Regularity and massive parallel computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : We explore the link between dependence abstractions and maximal parallelism extraction in nested loops. Our goal is to find, for each dependence abstraction, the minimal transformations needed for maximal parallelism extraction. The result of this paper is that Allen and Kennedy's algorithm is optimal when dependences are approximated by dependence levels. This means that even the most sophisticated algorithm cannot detect more parallelism than found by Allen and Kennedy's algorithm, as long as dependence level is the only information available. In other words, loop distribution is sufficient for detecting maximal parallelism in dependence graphs with levels.
Complete list of metadata
https://hal.inria.fr/hal-00856887
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Monday, September 2, 2013 - 4:19:09 PM
Last modification on : Wednesday, March 2, 2022 - 1:28:03 PM
Links full text
Identifiers
Collections
Citation
Alain Darte, Frédéric Vivien. On the Optimality of Allen and Kennedy's Algorithm for Parallelism Extraction in Nested Loops. Parallel Algorithms and Applications, Informa UK (Taylor & Francis), 1997, 12 (1-3), pp.83-112. ⟨10.1080/01495739708941417⟩. ⟨hal-00856887⟩
Share
Metrics
Record views
54
