Combining Retiming and Scheduling Techniques for Loop Parallelization and Loop Tiling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel Processing Letters Année : 1997
Tiling is a technique used for exploiting medium-grain parallelism in nested loops. It relies on a first step that detects sets of permutable nested loops. All algorithms developed so far consider the statements of the loop body as a single block, in other words, they are not able to take advantage of the structure of dependences between different statements. In this paper, we overcome this limitation by showing how the structure of the reduced dependence graph can be taken into account for detecting more permutable loops. Our method combines graph retiming techniques and graph scheduling techniques. It can be viewed as an extension of the Wolf and Lam's algorithm to the case of loops with multiple statements. Loop independent dependences play a particular role in our study, and we show how the way we handle them can be useful for fine-grain parallelization as well.
Fichier non déposé
hal-00856890 , version 1 (02-09-2013)
Alain Darte, Georges-André Silber, Frédéric Vivien. Combining Retiming and Scheduling Techniques for Loop Parallelization and Loop Tiling. Parallel Processing Letters, 1997, 7 (4), pp.379--392. ⟨10.1142/S0129626497000383⟩. ⟨hal-00856890⟩
143 Consultations
0 Téléchargements
