Conference papers
Tiling With Limited Resources
Pierre-Yves Calland 1 Jack Dongarra 2 Yves Robert 1
1 REMAP - Regularity and massive parallel computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : In the framework of perfect loop nests with uniform dependences, tiling has been extensively studied as a source-to-source program transformation. Little work has been devoted to the mapping and scheduling of the tiles on to physical processors. We present several new results in the context of limited computational resources, and assuming communication-computation overlap. In particular, under some reasonable assumptions, we derive the optimal mapping and scheduling of tiles to physical processors
Complete list of metadata
https://hal.inria.fr/hal-00856895
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Monday, September 2, 2013 - 4:19:14 PM
Last modification on : Friday, February 4, 2022 - 3:16:52 AM
Links full text
Identifiers
Collections
Citation
Pierre-Yves Calland, Jack Dongarra, Yves Robert. Tiling With Limited Resources. Application Specific Systems, Architectures and Processors, Jul 1997, Zurich, Switzerland. pp.229-238, ⟨10.1109/ASAP.1997.606829⟩. ⟨hal-00856895⟩
Share
Metrics
Record views
95
