Parallel Gaussian elimination on a MIMD computer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel Computing Année : 1988
This paper introduces a graph-theoretic approach to analyse the performances of several parallel Gaussian-like triangularization algorithms on an MIMD computer. We show that the SAXPY, GAXPY and DOT algorithms of Dongarra, Gustavson and Karp, as well as parallel versions of the LDMt, LDLt, Doolittle and Cholesky algorithms, can be classified into four task graph models. We derive new complexity results and compare the asymptotic performances of these parallel versions.
hal-00857005 , version 1 (02-09-2013)
Michel Cosnard, Mounir Marrakchi, Yves Robert, Denis Trystram. Parallel Gaussian elimination on a MIMD computer. Parallel Computing, 1988, 6 (3), pp.275-296. ⟨10.1016/0167-8191(88)90070-1⟩. ⟨hal-00857005⟩
146 Consultations
0 Téléchargements
