Approximating bounded, non-orientable surfaces from points, Shape Modeling International, pp.243-252, 2004. ,
On normals and projection operators for surfaces defined by point sets, Proc. Eurographics Symposium on Point-Based Graphics, pp.149-156, 2004. ,
Interpolatory point set surfaces-convexity and hermite data, ACM Transactions on Graphics (TOG), vol.28, issue.20 7, 2009. ,
Voronoi-based variational reconstruction of unoriented point sets, Proc. Eurographics Symposium on Geometry Processing, pp.39-48, 2007. ,
Defining point-set surfaces, ACM Trans. Graph, vol.23, issue.2 4, pp.264-270, 2004. ,
Optimal orientation detection of linear symmetry, Proc. IEEE International Conference on Computer Vision, pp.433-438, 1987. ,
Adaptive structure tensors and their applications. In Visualization and image processing of tensor fields, pp.17-47, 2006. ,
Robust moving least-squares fitting with sharp features, ACM Trans. Graph, vol.24, issue.3 10, pp.544-552, 2005. ,
Algebraic point set surfaces, ACM Trans. Graph, vol.26, issue.3, 2007. ,
Dynamic sampling and rendering of algebraic point set surfaces, Computer Graphics Forum, vol.27, issue.3, p.7, 2008. ,
Surface reconstruction from unorganized points, Proc. SIGGRAPH '92, pp.71-78, 1992. ,
Painterly rendering with curved brush strokes of multiple sizes, Proc. SIGGRAPH '98, pp.453-460, 1998. ,
Consolidation of unorganized point clouds for surface reconstruction, ACM Trans. Graph, vol.28, issue.2, p.5, 2009. ,
Poisson surface reconstruction, Proc. Eurographics Symposium on Geometry Processing, pp.43-52, 2006. ,
Image and video abstraction by coherence-enhancing filtering, Computer Graphics Forum, vol.30, issue.2 6, pp.593-602, 2011. ,
Image and video abstraction by anisotropic kuwahara filtering, Computer Graphics Forum, vol.28, issue.7 1, pp.1955-1963, 2009. ,
Coherent line drawing, NPAR'07: Proc. symposium on Non-photorealistic animation and rendering ACM/Eurographics, pp.43-50, 2007. ,
Flow-based image abstraction, IEEE Trans. Visualization and Comput. Graph, vol.15, issue.2 6, pp.62-76, 2009. ,
The approximation power of moving leastsquares, Mathematics of Computation, vol.67, pp.1517-1531, 1998. ,
Volume MLS Ray Casting, IEEE Transactions on Visualization and Computer Graphics, vol.14, issue.6, pp.1372-1379, 2008. ,
DOI : 10.1109/TVCG.2008.186
On differentiating eigenvalues and eigenvectors, Econometric Theory, vol.24, issue.1, pp.179-191, 1985. ,
Growing Least Squares for the Continuous Analysis of Manifolds in Scale-Space, Computer Graphics Forum, vol.10, p.11, 2012. ,
Signing the Unsigned: Robust Surface Reconstruction from Raw Pointsets, Computer Graphics Forum, vol.2005, issue.5, pp.1733-1741, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01782.x
GUIBAS: Estimating surface normals in noisy point cloud data, International Journal of Computational Geometry and Applications, issue.2, 2004. ,
Parameterizing singularities of positive integral index Feature preserving point set surfaces based on non-linear kernel regression, 13th IMA International Conference on Mathematics of Surfaces XIII, pp.265-277, 2009. ,
Continuous glass patterns for painterly rendering, Image Processing IEEE Transactions, vol.18, issue.1 6, pp.652-664, 2009. ,
Direct least-squares fitting of algebraic surfaces, Proc. SIGGRAPH '87, pp.145-152, 1987. ,
Image deformation using moving least squares, ACM Trans. Graph, vol.25, issue.3, pp.533-540, 2006. ,
Interpolating and approximating implicit surfaces from polygon soup, ACM Transactions on Graphics, vol.23, issue.3, pp.896-904, 2004. ,
DOI : 10.1145/1015706.1015816
Estimation of planar curves, surfaces, and nonplanar space curves defined by implicit equations with applications to edge and range image segmentation, IEEE Trans. Pattern Anal. Mach. Intell, vol.13, pp.11-1115, 1991. ,
Bilateral filtering for gray and color images, Computer Vision Sixth International Conference on, pp.839-846, 1998. ,
XDoG: advanced image stylization with eXtended Difference-of-Gaussians, NPAR '11 :Proc. symposium on Non-Photorealistic Animation and Rendering ACM/Eurographics, pp.147-156, 2011. ,
Feature-aligned shape texturing, ACM Trans. Graph, vol.28, issue.108, pp.51-108, 2009. ,
Interactive tensor field design and visualization on surfaces, IEEE Trans. Visualization and Computer Graphics, vol.13, issue.1 2, pp.94-107, 2007. ,
