Further results on input-to-state stability for nonlinear systems with delayed feedbacks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2008
Frédéric Mazenc
Zongli Lin
  • Fonction : Auteur
We consider a class of nonlinear control systems for which stabilizing feedbacks and corresponding Lyapunov functions for the closed-loop systems are available. In the presence of feedback delays and actuator errors, we explicitly construct input-to-state stability (ISS) Lyapunov-Krasovskii functionals for the resulting feedback delayed dynamics, in terms of the available Lyapunov functions for the original undelayed dynamics, which establishes that the closed-loop systems are input-to-state stable (ISS) with respect to actuator errors. We illustrate our results using a generalized system from identification theory and other examples.
hal-00857808 , version 1 (04-09-2013)
Frédéric Mazenc, Michael Malisoff, Zongli Lin. Further results on input-to-state stability for nonlinear systems with delayed feedbacks. Automatica, 2008, 44 (9), pp.2415-2421. ⟨10.1016/j.automatica.2008.01.024⟩. ⟨hal-00857808⟩
80 Consultations
0 Téléchargements
