Biological control of the chemostat with nonmonotonic response and different removal rates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Biosciences and Engineering Année : 2008
We show the global stabilization of the chemostat with nonmonotonic growth, adding a new species as a "biological" control, in presence of different removal rates for each species. This result is obtained by an extension of the Competitive Exclusion Principle in the chemostat, for the case of two species with different removal rates and at least one nonmonotonic response.
hal-00857810 , version 1 (04-09-2013)
Alain Rapaport, Jérôme Harmand. Biological control of the chemostat with nonmonotonic response and different removal rates. Mathematical Biosciences and Engineering, 2008, 5 (3), pp.539-547. ⟨10.3934/mbe.2008.5.539⟩. ⟨hal-00857810⟩
198 Consultations
0 Téléchargements
