Dynamic load balancing in computational mechanics, Computer Methods in Applied Mechanics and Engineering, vol.184, issue.2-4, pp.485-500, 2000. ,
DOI : 10.1016/S0045-7825(99)00241-8
Partitioning and Dynamic Load Balancing for the Numerical Solution of Partial Differential Equations, Numerical Solution of Partial Differential Equations on Parallel Computers, pp.55-88, 2006. ,
DOI : 10.1007/3-540-31619-1_2
Performance analysis of dynamic load balancing algorithms with variable number of processors, Journal of Parallel and Distributed Computing, vol.65, issue.8, pp.934-948, 2005. ,
DOI : 10.1016/j.jpdc.2005.04.003
Performance of parallel computations with dynamic processor allocation, Engineering with Computers, vol.29, issue.8, pp.135-143, 2008. ,
DOI : 10.1007/s00366-007-0078-6
PLUM : Parallel Load Balancing for Adaptive Unstructured Meshes, Journal of Parallel and Distributed Computing, vol.52, issue.2, pp.150-177, 1998. ,
DOI : 10.1006/jpdc.1998.1469
Multilevel Diffusion Schemes for Repartitioning of Adaptive Meshes, Journal of Parallel and Distributed Computing, vol.47, issue.2, pp.109-124, 1997. ,
DOI : 10.1006/jpdc.1997.1410
Wavefront diffusion and LMSR: algorithms for dynamic repartitioning of adaptive meshes, IEEE Transactions on Parallel and Distributed Systems, vol.12, issue.5, pp.451-466, 2001. ,
DOI : 10.1109/71.926167
Adaptive decomposition and remapping algorithms for object-space-parallel direct volume rendering of unstructured grids, Journal of Parallel and Distributed Computing, vol.67, issue.1, pp.77-99, 2007. ,
DOI : 10.1016/j.jpdc.2006.05.005
A repartitioning hypergraph model for dynamic load balancing, J. Parallel Distrib. Comput, vol.69, issue.8, pp.711-724, 2009. ,
Dynamic load-balancing with variable number of processors based on graph repartitioning, 2012 19th International Conference on High Performance Computing, p.2012 ,
DOI : 10.1109/HiPC.2012.6507501
URL : https://hal.archives-ouvertes.fr/hal-00722731
Parallel incremental graph partitioning using linear programming, Proceedings Supercomputing '94, pp.458-467, 1994. ,
An optimal migration algorithm for dynamic load balancing. Concurrency: Practice and Experience, pp.467-483, 1998. ,
A linear-time heuristic for improving network partitions, 19th Design Automation Conference, pp.175-181, 1982. ,
The university of Florida sparse matrix collection, ACM Trans. Math. Softw, vol.381, issue.1, pp.1-125, 2011. ,
