A comparitive study of energy minimization methods for Markov random fields with smoothness-based priors, 2008. ,
Multiscale conditional random fields for image labeling, CVPR, 2004. ,
Statistical cues for domain specific image segmentation with performance analysis, Proceedings IEEE Conference on Computer Vision and Pattern Recognition. CVPR 2000 (Cat. No.PR00662), 2000. ,
DOI : 10.1109/CVPR.2000.855809
TextonBoost: Joint Appearance, Shape and Context Modeling for Multi-class Object Recognition and Segmentation, ECCV, 2006. ,
DOI : 10.1007/11744023_1
Combining appearance models and Markov Random Fields for category level object segmentation, 2008 IEEE Conference on Computer Vision and Pattern Recognition, 2008. ,
DOI : 10.1109/CVPR.2008.4587453
URL : https://hal.archives-ouvertes.fr/inria-00548660
Make3D: Learning 3D Scene Structure from a Single Still Image, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.31, issue.5, 2008. ,
DOI : 10.1109/TPAMI.2008.132
From contours to regions: An empirical evaluation, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206707
Mean shift analysis and applications, Proceedings of the Seventh IEEE International Conference on Computer Vision, 1997. ,
DOI : 10.1109/ICCV.1999.790416
Object Recognition by Integrating Multiple Image Segmentations, ECCV, 2008. ,
DOI : 10.1007/978-3-540-88690-7_36
Harmony potentials for joint classification and segmentation, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2010. ,
DOI : 10.1109/CVPR.2010.5540048
Robust higher order potentials for enforcing label consistency, CVPR, 2008. ,
Associative hierarchical CRFs for object class image segmentation, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459248
Object recognition as ranking holistic figure-ground hypotheses, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2010. ,
DOI : 10.1109/CVPR.2010.5539839
Decomposing a scene into geometric and semantically consistent regions, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459211
Global connectivity potentials for random field models, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206567
Graph cut based image segmentation with connectivity priors, 2008 IEEE Conference on Computer Vision and Pattern Recognition, 2008. ,
DOI : 10.1109/CVPR.2008.4587440
The Pascal Visual Object Classes (VOC) Challenge, International Journal of Computer Vision, vol.73, issue.2, 2010. ,
DOI : 10.1007/s11263-009-0275-4
A discriminatively trained, multiscale, deformable part model, 2008 IEEE Conference on Computer Vision and Pattern Recognition, 2008. ,
DOI : 10.1109/CVPR.2008.4587597
Learning structural SVMs with latent variables, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553523
Self-paced learning for latent variable models, NIPS, 2010. ,
Efficiently selecting regions for scene understanding, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2010. ,
DOI : 10.1109/CVPR.2010.5540072
Learning specific-class segmentation from diverse data, 2011 International Conference on Computer Vision, 2011. ,
DOI : 10.1109/ICCV.2011.6126446
A linear programming formulation and approximation algorithms for the metric labelling problem, Disc. Math, 2005. ,
MAP Estimation Via Agreement on Trees: Message-Passing and Linear Programming, IEEE Transactions on Information Theory, vol.51, issue.11, 2005. ,
DOI : 10.1109/TIT.2005.856938
Some network flow problems solved with pseudo-Boolean programming, Operations Research, 1965. ,
Optimizing Binary MRFs via Extended Roof Duality, 2007 IEEE Conference on Computer Vision and Pattern Recognition, 2007. ,
DOI : 10.1109/CVPR.2007.383203
Pseudo-Boolean optimization, Discrete Applied Mathematics, vol.123, issue.1-3, 2002. ,
DOI : 10.1016/S0166-218X(01)00341-9
URL : https://hal.archives-ouvertes.fr/hal-01150533
Beyond Loose LP-Relaxations: Optimizing MRFs by Repairing Cycles, ECCV, 2008. ,
DOI : 10.1007/978-3-540-88690-7_60
URL : https://hal.archives-ouvertes.fr/hal-00918715
Efficiently solving convex relaxations for MAP estimation, Proceedings of the 25th international conference on Machine learning, ICML '08, 2008. ,
DOI : 10.1145/1390156.1390242
Tightening LP relaxations for MAP using message passing, UAI, 2008. ,
On the cut polytope, Mathematical Programming, 1986. ,
DOI : 10.1007/BF02592023
MRF Optimization via Dual Decomposition: Message-Passing Revisited, 2007 IEEE 11th International Conference on Computer Vision, 2007. ,
DOI : 10.1109/ICCV.2007.4408890
Probabilistic Reasoning in Intelligent Systems: Networks of Plausible Inference, 1998. ,
Beyond pairwise energies: Efficient optimization for higher-order MRFs, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206846
Minimizing sparse higher order energy functions of discrete variables, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206739
Recognition using regions, CVPR, 2009. ,
Geometric context from a single image, Tenth IEEE International Conference on Computer Vision (ICCV'05) Volume 1, 2005. ,
DOI : 10.1109/ICCV.2005.107
Towards total scene understanding: Classification, annotation and segmentation in an automatic framework, CVPR, 2009. ,
Making large-scale SVM learning practical, Advances in Kernel Methods, 1999. ,
Fast approximate energy minimization via graph cuts, 2001. ,
DOI : 10.1109/iccv.1999.791245
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.6806
ImageNet: A large-scale hierarhical image database, CVPR, 2009. ,
Pegasos, Proceedings of the 24th international conference on Machine learning, ICML '07, 2009. ,
DOI : 10.1145/1273496.1273598
Image segmentation with a bounding box prior, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459262
Using Multiple Segmentations to Discover Objects and their Extent in Image Collections, 2006 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, Volume 2 (CVPR'06), 2006. ,
DOI : 10.1109/CVPR.2006.326
