Optimizing Compilers for Modern Architectures: A Dependence- Based Approach, 2002. ,
Performance Tuning of x86 OpenMP Codes with MAQAO, 2010. ,
DOI : 10.1007/978-3-642-11261-4_7
Vectorizing compilers: a test suite and results, Proceedings. SUPERCOMPUTING '88, 1988. ,
DOI : 10.1109/SUPERC.1988.44642
Efficiently computing static single assignment form and the control dependence graph, ACM Transactions on Programming Languages and Systems, vol.13, issue.4, 1991. ,
DOI : 10.1145/115372.115320
Vectorization for SIMD architectures with alignment constraints, ACM SIGPLAN Conf. on Programming Language Design and Implementation, 2004. ,
Predictive modeling in a polyhedral optimization space, In: ACM/IEEE Intl. Conf. on Code Generation and Optimization, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00918653
Dynamic trace-based analysis of vectorization potential of applications, ACM SIGPLAN Conf. on Programming Language Design and Implementation, 2012. ,
Prediction and trace compression of data access addresses through nested loop recognition, Proceedings of the sixth annual IEEE/ACM international symposium on Code generation and optimization , CGO '08, pp.94-103, 2008. ,
DOI : 10.1145/1356058.1356071
URL : https://hal.archives-ouvertes.fr/inria-00504597
When polyhedral transformations meet SIMD code generation, ACM SIGPLAN Conf. on Programming Language Design and Implementation, 2013. ,
DOI : 10.1145/2491956.2462187
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.307.4089
Scout: A Source-to-Source Transformator for SIMD-Optimizations, 2011. ,
DOI : 10.1007/978-3-642-29740-3_17
Exploiting superword level parallelism with multimedia instruction sets, In: ACM SIGPLAN Conf. on Programming Language Design and Implementation, 2000. ,
DOI : 10.1145/358438.349320
URL : http://cag.lcs.mit.edu/commit/papers/00/SLarsen-SM.pdf
Pin: building customized program analysis tools with dynamic instrumentation, ACM SIGPLAN Conf. on Programming Language Design and Implementation, 2005. ,
Limits of parallelism using dynamic dependency graphs, Proceedings of the Seventh International Workshop on Dynamic Analysis, WODA '09, 2009. ,
DOI : 10.1145/2134243.2134253
An evaluation of vectorization compilers, International Conference on Parallel Architectures and Compilation Techniques (PACT), 2011. ,
Vapor SIMD: Auto-vectorize once, run everywhere, International Symposium on Code Generation and Optimization (CGO 2011), 2011. ,
DOI : 10.1109/CGO.2011.5764683
URL : https://hal.archives-ouvertes.fr/inria-00589692
Multi-platform Auto-vectorization, International Symposium on Code Generation and Optimization (CGO'06), 2006. ,
DOI : 10.1109/CGO.2006.25
Auto-vectorization of interleaved data for SIMD, ACM SIGPLAN Conf. on Programming Language Design and Implementation, 2006. ,
Autovectorization in GCC-two years later, Proceedings of the GCC Developers Summit, 2006. ,
Static and dynamic evaluation of data dependence analysis, International Conference on Supercomputing, 1993. ,
ispc: A SPMD compiler for high-performance CPU programming, 2012 Innovative Parallel Computing (InPar), 2012. ,
DOI : 10.1109/InPar.2012.6339601
Towards a holistic approach to autoparallelization: integrating profile-driven parallelism detection and machine-learning based mapping, In: ACM SIGPLAN Conf. on Programming Language Design and Implementation, 2009. ,
Polyhedral-model guided loopnest auto-vectorization, International Conference on Parallel Architectures and Compilation Techniques, 2009. ,
DOI : 10.1109/pact.2009.18
URL : https://hal.archives-ouvertes.fr/hal-00645325
