New interface
Conference papers
Cortex parcellation via diffusion data as prior knowledge for the MEG inverse problem
Abstract : In this paper, we present a new approach to the recovery of dipole magnitudes in a distributed source model for magnetoencephalographic (MEG) imaging. This method consists in introducing prior knowledge regarding the anatomical connectivity in the brain to this ill-posed inverse problem. Thus, we perform cortex parcellation via structural information coming from diffusion MRI (dMRI), the only non-invasive modality allowing to have access to the structure of the WM tissues. Then, we constrain, in the MEG inverse problem, sources in the same diffusion parcel to have close magnitude values. Results of our method on MEG simulations are presented and favorably compared with classical source reconstruction methods.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00858019
Contributor : Théodore Papadopoulo Connect in order to contact the contributor
Submitted on : Wednesday, September 4, 2013 - 2:16:37 PM
Last modification on : Saturday, June 25, 2022 - 11:11:02 PM
Identifiers
Collections
Citation
Anne-Charlotte Philippe, Maureen Clerc, Théodore Papadopoulo, Rachid Deriche. Cortex parcellation via diffusion data as prior knowledge for the MEG inverse problem. Biomedical Imaging (ISBI), 2013 IEEE 10th International Symposium on, Apr 2013, San Francisco, United States. pp.994-997, ⟨10.1109/ISBI.2013.6556644⟩. ⟨hal-00858019⟩
Share
Metrics
Record views
142
