Kinetic schemes on staggered grids for barotropic Euler models: entropy-stability analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We introduce a new scheme of finite volume type for barotropic Euler equations. The numerical unknowns, namely densities and velocities, are defined on staggered grids. The numerical fluxes are defined by using the framework of kinetic schemes. We can consider general (convex) pressure laws. We justify that the density remains non negative and the total physical entropy does not increase, under suitable stability conditions. Performances of the scheme are illustrated through a set of numerical experiments.
StaggKS_BGM_13.pdf (983.18 Ko) Télécharger le fichier
hal-00858252 , version 1 (05-09-2013)
hal-00858252 , version 2 (27-08-2014)
  • HAL Id : hal-00858252 , version 1
Florent Berthelin, Thierry Goudon, Sebastian Minjeaud. Kinetic schemes on staggered grids for barotropic Euler models: entropy-stability analysis. 2013. ⟨hal-00858252v1⟩
488 Consultations
338 Téléchargements
