Can the minimum rule of possibility theory be extended to belief functions?
Abstract : When merging belief functions, Dempster rule of combination is justified only when sources can be considered as independent,. When dependencies are ill-known, it is usual to ask the merging operation to satisfy the property of idempotence, as this property ensures a cautious behaviour in the face of dependent sources. There are different strategies to find such rules for belief functions. One strategy is to rely on idempotent rules used in either more general or more specific frameworks and to respectively study their particularisation or extension to belief functions. In this paper, we try to extend the minimum rule of possibility theory to belief functions. We show that such ail extension is riot always possible, unless we accept the idea that the result; of the fusion process can be a family of belief functions.
Type de document :
Article dans une revue
Lecture Notes in Computer Science, Springer, 2009, 5590, pp.299-310
Liste complète des métadonnées
https://hal.inria.fr/hal-00858538
Contributeur : Alain Rapaport <>
Soumis le : jeudi 5 septembre 2013 - 15:36:15
Dernière modification le : mercredi 19 décembre 2018 - 13:08:13
  • HAL Id : hal-00858538, version 1
Collections
Citation
Sébastien Destercke, Didier Dubois. Can the minimum rule of possibility theory be extended to belief functions?. Lecture Notes in Computer Science, Springer, 2009, 5590, pp.299-310. 〈hal-00858538〉
Métriques
Consultations de la notice
117
