Simulation and optimization software for alcoholic fermentation in winemaking conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Food Control Année : 2009
Anne Goelzer
Brigitte Charnomordic
  • Fonction : Auteur
  • PersonId : 1202749
Vincent Fromion
Jean-Marie Sablayrolles
The kinetics and duration of winemaking fermentations may vary considerably as a function of must composition and thermal conditions. This makes it difficult to manage tanks and power use in wine production. Modern decision support tools may help, but are difficult to use, as the underlying optimization problem is complex and its solution is time-consuming. We developed a decision support software based on a physiological model of yeast activity, including a mathematical model of heat transfer. The integrated decision support module uses fuzzy logic and a heuristic approach to provide efficient, rapid solutions to facilitate winery management at an industrial scale in various winemaking conditions. The applications of this software are illustrated using various realistic cases. (c) 2008 Elsevier Ltd. All rights reserved
Autre [cs.OH]
hal-00858545 , version 1 (05-09-2013)
Anne Goelzer, Brigitte Charnomordic, S. Colombié, Vincent Fromion, Jean-Marie Sablayrolles. Simulation and optimization software for alcoholic fermentation in winemaking conditions. Food Control, 2009, 20 (7), pp.635-642. ⟨10.1016/j.foodcont.2008.09.016⟩. ⟨hal-00858545⟩
142 Consultations
0 Téléchargements
