Bayesian BOLD and perfusion source separation and deconvolution from functional ASL imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In many neuroscience applications, the Arterial Spin Labeling (ASL) fMRI modality arises as a preferable choice to the standard BOLD modality due to its ability to provide a quantitative measure of the Cerebral Blood Flow (CBF). Such a quantification is central but generally performed without consideration of a specific modeling of the perfusion component in the signal often handled via standard GLM approaches using the BOLD canonical response function as regressor. In this work, we propose a novel Bayesian hierarchical model of the ASL signal which allows activation detection and both the extraction of a perfusion and a hemodynamic component. Validation on synthetic and real data sets from event-related ASL show the ability of our model to address the source separation and double deconvolution problems inherent to ASL data analysis.
vincent.pdf (591.61 Ko) Télécharger le fichier
hal-00859373 , version 1 (07-09-2013)
Thomas Vincent, Florence Forbes, Philippe Ciuciu. Bayesian BOLD and perfusion source separation and deconvolution from functional ASL imaging. ICASSP 2013 - IEEE International Conference on Acoustics, Speech, and Signal Processing, May 2013, Vancouver, Canada. pp.1003-1007, ⟨10.1109/ICASSP.2013.6637800⟩. ⟨hal-00859373⟩
780 Consultations
260 Téléchargements
