The cortical column: A new processing unit for multilayered networks, Neural Networks, vol.4, issue.1, pp.15-25, 1991. ,
DOI : 10.1016/0893-6080(91)90027-3
Not Just for Bimodal Neurons Anymore: The Contribution of Unimodal Neurons to Cortical Multisensory Processing, Brain Topography, vol.91, issue.3-4, pp.157-167, 2009. ,
DOI : 10.1007/s10548-009-0088-3
Dynamics of pattern formation in lateralinhibition type neural fields, BiolCyb, vol.27, pp.77-87, 1977. ,
Cortical connections and parallel processing: Structure and function, Behavioral and Brain Sciences, vol.3, issue.01, pp.67-90, 1986. ,
DOI : 10.1016/0306-4522(81)90235-9
The spatiotemporal organization of auditory, visual, and auditory-visual evoked potentials in rat cortex, Brain Research, vol.678, issue.1-2, pp.177-190, 1995. ,
DOI : 10.1016/0006-8993(95)00182-P
Visual???auditory spatial processing in auditory cortical neurons, Brain Research, vol.1242, pp.24-36, 2008. ,
DOI : 10.1016/j.brainres.2008.02.087
Data analysis: How to compare kohonen neural networks to other techniques? Artificial neural networks, pp.469-476, 1991. ,
DOI : 10.1007/bfb0035929
Orientation selectivity and the arrangement of horizontal connections in tree shrew striate cortex, The Journal of Neuroscience, vol.17, issue.6, p.2112, 1997. ,
An adaptive neural network: the cerebral cortex, 1990. ,
The handbook of multisensory processes, 2004. ,
Intermodality inconsistency of input and directed attention as determinants of the nature of adaptation., Journal of Experimental Psychology, vol.84, issue.1, p.141, 1970. ,
DOI : 10.1037/h0028925
Multisensory anatomical pathways, Hearing Research, vol.258, issue.1-2, pp.28-36, 2009. ,
DOI : 10.1016/j.heares.2009.04.017
URL : https://hal.archives-ouvertes.fr/hal-00435518
Fuzzy ARTMAP: A neural network architecture for incremental supervised learning of analog multidimensional maps, IEEE Transactions on Neural Networks, vol.3, issue.5, pp.698-713, 1992. ,
DOI : 10.1109/72.159059
Cross-modal Circuitry Between Auditory and Somatosensory Areas of the Cat Anterior Ectosylvian Sulcal Cortex: A 'New' Inhibitory Form of Multisensory Convergence, Cerebral Cortex, vol.14, issue.4, pp.387-403, 2004. ,
DOI : 10.1093/cercor/bhg135
Reorganization of Human Cerebral Cortex: The Range of Changes Following Use and Injury, The Neuroscientist, vol.10, issue.2, pp.129-141, 2004. ,
DOI : 10.1177/1073858403262111
Adaptive pattern classification and universal recoding: I. Parallel development and coding of neural feature detectors, Biological Cybernetics, vol.28, issue.3, pp.121-134, 1976. ,
DOI : 10.1007/BF00344744
Functional mapping of cortical areas with optical imaging, NeuroImage, vol.37, issue.2, pp.440-448, 2007. ,
DOI : 10.1016/j.neuroimage.2007.04.059
Shape and arrangement of columns in cat's striate cortex, The Journal of Physiology, vol.165, issue.3, pp.559-568, 1963. ,
DOI : 10.1113/jphysiol.1963.sp007079
Towards cortex sized artificial neural systems, Neural Networks, vol.20, issue.1, pp.48-61, 2007. ,
DOI : 10.1016/j.neunet.2006.05.029
Associative Self-Organizing Map, International Joint Conference on Computational Intelligence (IJCCI, pp.363-370, 2009. ,
DOI : 10.5772/13168
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.157.6067
Self-organized formation of topologically correct feature maps, Biological Cybernetics, vol.13, issue.1, pp.59-69, 1982. ,
DOI : 10.1007/BF00337288
Apprentissage spatial de corrélations multimodales par des mécanismes d'inspiration corticale, 2012. ,
Coupling bcm and neural fields for the emergence of self-organization consensus. From Brains to Systems, pp.41-56, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00585493
Unlearning in the BCM Learning Rule for Plastic Self-organization in a Multi-modal Architecture, Artificial Neural Networks and Machine Learning?ICANN 2011, pp.93-100, 2011. ,
DOI : 10.1016/j.neunet.2005.04.004
URL : https://hal.archives-ouvertes.fr/inria-00585672
Cerebral cortex: architecture, intracortical connections, motor projections. Physiology of the nervous system, pp.288-330, 1949. ,
Anatomical Substrates for Functional Columns in Macaque Monkey Primary Visual Cortex, Cerebral Cortex, vol.13, issue.1, pp.15-24, 2003. ,
DOI : 10.1093/cercor/13.1.15
Model of multi-modal cortical processing: Coherent learning in self-organizing modules, Neural Networks, vol.18, issue.5-6, pp.646-655, 2005. ,
DOI : 10.1016/j.neunet.2005.06.036
Processing in layer 4 of the neocortical circuit: new insights from visual and somatosensory cortex, Current Opinion in Neurobiology, vol.11, issue.4, pp.488-497, 2001. ,
DOI : 10.1016/S0959-4388(00)00239-7
Modality and topographic properties of single neurons of cats somatic sensory cortex, J. Neurophysiol, vol.20, issue.4, pp.408-434, 1957. ,
The after-effects of ventriloquism, Quarterly Journal of Experimental Psychology, vol.28, issue.1, p.63, 1974. ,
DOI : 10.1080/14640747408400388
Guidance of neurons migrating to the fetal monkey neocortex Emergence of attention within a neural population, Brain research Neural Networks, vol.33, issue.195, pp.471573-581, 1971. ,
Order and disorder in auditory cortical maps, Current Opinion in Neurobiology, vol.5, issue.4, pp.489-496, 1995. ,
DOI : 10.1016/0959-4388(95)80010-7
Multisensory contributions to low-level, ???unisensory??? processing, Current Opinion in Neurobiology, vol.15, issue.4, pp.454-458, 2005. ,
DOI : 10.1016/j.conb.2005.06.008
Unsupervised model for grounding multimodal representations, 2010. ,
