A Component-Based Approach for Specifying Reusable Visual Languages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Model-Driven Engineering (MDE) encourages the use of graphical modeling tools, which facilitate the development process from modeling to coding. Such tools can be designed using the MDE approach into metamodeling environments called metaCASE tools. It turned out that current metaCASE tools still require, in most cases, manual programming to build full tool support for the modeling language, especially for users' native methodologies and representational elements and suffer from gaps in terms of reusability. In this context, we propose MID, a set of metamodels supporting the specification of modeling editors by means of reusable components and explain how representational metamodeling is carried out with it.
VLHCC13.pdf (644.58 Ko) Télécharger le fichier
hal-00860909 , version 1 (17-09-2013)
Amine El Kouhen, Sébastien Gerard, Cedric Dumoulin, Pierre Boulet. A Component-Based Approach for Specifying Reusable Visual Languages. 2013 IEEE Symposium on Visual Languages and Human-Centric Computing, Allen Cypher, Sep 2013, San José, CA, United States. pp.135-138, ⟨10.1109/VLHCC.2013.6645257⟩. ⟨hal-00860909⟩
262 Consultations
317 Téléchargements
