HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Alignment of Binocular-Binaural Data Using a Moving Audio-Visual Target
Vasil Khalidov 1 Florence Forbes 2 Radu Horaud 3
2 MISTIS - Modelling and Inference of Complex and Structured Stochastic Systems
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
3 PERCEPTION - Interpretation and Modelling of Images and Videos
Abstract : In this paper we address the problem of aligning visual (V) and auditory (A) data using a sensor that is composed of a camera-pair and a microphone-pair. The original contribution of the paper is a method for AV data aligning through estimation of the 3D positions of the microphones in the visual-centred coordinate frame defined by the stereo camera-pair. We exploit the fact that these two distinct data sets are conditioned by a common set of parameters, namely the (unknown) 3D trajectory of an AV object, and derive an EM-like algorithm that alternates between the estimation of the microphone-pair position and the estimation of the AV object trajectory. The proposed algorithm has a number of built-in features: it can deal with A and V observations that are misaligned in time, it estimates the reliability of the data, it is robust to outliers in both modalities, and it has proven theoretical convergence. We report experiments with both simulated and real data.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00861482
Contributor : Perception Team Connect in order to contact the contributor
Submitted on : Friday, October 4, 2013 - 5:14:26 PM
Last modification on : Tuesday, October 19, 2021 - 11:13:07 PM
Long-term archiving on: : Friday, April 7, 2017 - 6:53:11 AM
Identifiers
Citation
Vasil Khalidov, Florence Forbes, Radu Horaud. Alignment of Binocular-Binaural Data Using a Moving Audio-Visual Target. MMSP 2013 - IEEE International Workshop on Multimedia Signal Processing, IEEE Signal Processing Society, Sep 2013, Pula (Sardinia), Italy. pp.242-247, ⟨10.1109/MMSP.2013.6659295⟩. ⟨hal-00861482v3⟩
Share
Metrics
Record views
458
Files downloads
357
