D. P. Bertsekas, Dynamic Programming and Optimal Control, Athena Scientific, 2000.
S. J. Russell and P. Norvig, Artificial Intelligence -A Modern Approach (3. internat, 2010.
D. Koller and N. Friedman, Probabilistic Graphical Models: Principles and Techniques, 2009.
A. Odoni, The Flow Management Problem in Air Traffic Control Flow Control of Congested Networks, pp.269-288, 1987.
O. Richetta and A. R. Odoni, Dynamic solution to the ground-holding problem in air traffic control, Transportation Research Part A: Policy and Practice, vol.28, issue.3, pp.167-185, 1994.
DOI : 10.1016/0965-8564(94)90015-9
A. Mukherjee and M. Hansen, A Dynamic Stochastic Model for the Single Airport Ground Holding Problem, Transportation Science, vol.41, issue.4, pp.444-456, 2007.
DOI : 10.1287/trsc.1070.0210
P. Vranas, D. Bertsimas, and A. Odoni, The Multi-Airport Ground-Holding Problem in Air Traffic Control, Operations Research, vol.42, issue.2, pp.249-261, 1994.
DOI : 10.1287/opre.42.2.249
D. Bertsimas and S. S. Patterson, The Air Traffic Flow Management Problem with Enroute Capacities, Operations Research, vol.46, issue.3, pp.406-422, 1998.
DOI : 10.1287/opre.46.3.406
D. Bertsimas, G. Lulli, and A. R. Odoni, An Integer Optimization Approach to Large-Scale Air Traffic Flow Management, Operations Research, vol.59, issue.1, pp.211-227, 2011.
DOI : 10.1287/opre.1100.0899
A. Agustín, A. Alonso-ayuso, L. Escudero, and C. Pizarro, On Air Traffic Flow Management with Rerouting. Part I: Deterministic Case, European Journal of Operational Research, vol.219, issue.1, pp.156-166, 2012.
G. Clare and A. Richards, Air Traffic Flow Management Under Uncertainty: Application of Chance Constraints Application and Theory of Automation in Command and Control Systems, ser. ATACCS '12, Proceedings of the 2 nd International Conference on, pp.20-26, 2012.
S. Oussedik, D. Delahaye, and M. Schoenauer, Air Traffic Management by Stochastic Optimization, nd USA, pp.1-10, 1998.
URL : https://hal.archives-ouvertes.fr/hal-01205260
N. Barnier, P. Brisset, and T. Rivì-ere, Slot Allocation with Constraint Programming: Models and Results, Europe R&D Seminar on Air Traffic Management, 2001.
URL : https://hal.archives-ouvertes.fr/hal-00938015
P. Flener, J. Pearson, M. Agren, C. Garcia-avello, M. Celiktin et al., Air-Traffic Complexity Resolution in Multi-Sector Planning using Constraint Programming, 2007.
D. Delahaye, S. Oussedik, and S. Puechmorel, Airspace Congestion Smoothing by Multi-Objective Genetic Algorithm, Proceedings of the 2005 ACM symposium on Applied computing, ser. SAC '05, pp.907-912, 2005.
URL : https://hal.archives-ouvertes.fr/hal-01004145
E. P. Gilbo and S. B. Smith, New method for probabilistic traffic demand predictions for en route sectors based on uncertain predictions of individual flight events, Ninth USA/Europe Air Traffic Management Research and Development Seminar (ATM2011), 2011.
S. Puechmorel and D. Delahaye, Dynamical systems complexity with a view towards air traffic management applications, Proceedings of the 48h IEEE Conference on Decision and Control (CDC) held jointly with 2009 28th Chinese Control Conference, pp.8369-8374, 2009.
DOI : 10.1109/CDC.2009.5400549
URL : https://hal.archives-ouvertes.fr/hal-01018355
P. Kopardekar, Dynamic Density ? A Review of Proposed Variables Federal Aviation Administration, 2000.
B. Sridhar, S. R. Grabbe, and A. Mukherjee, Modeling and Optimization in Traffic Flow Management, Proceedings of the IEEE, pp.1-29, 2008.
A. Eiben and J. Smith, Introduction to Evolutionary Computing, 2003.
K. Deb, Multi-Objective Optimization Using Evolutionary Algorithms, 2001.
C. A. Coello, D. A. Veldhuizen, and G. B. Lamont, Evolutionary Algorithms for Solving Multi-Objective Problems, 2002.
DOI : 10.1007/978-1-4757-5184-0
C. A. Coello, G. B. Lamont, and E. , Application of Multi-Objective Evolutionary Algorithms Increasing Air Traffic: What is the Problem, The Second SESAR Innovation Days, p.2012, 2004.
K. Deb, A. Pratap, S. Agarwal, and T. Meyarivan, A fast and elitist multiobjective genetic algorithm: NSGA-II, IEEE Transactions on Evolutionary Computation, vol.6, issue.2, pp.182-197, 2000.
DOI : 10.1109/4235.996017
C. Igel, N. Hansen, and S. Roth, Covariance Matrix Adaptation for Multi-objective Optimization, Evolutionary Computation, vol.15, issue.1, pp.1-28, 2007.
DOI : 10.1109/TEVC.2003.810758
