Mixedinteger quadrangulation, SIGGRAPH '09: ACM SIGGRAPH 2009 papers, pp.1-10, 2009. ,
Quadrangular parameterization for reverse engineering, Proc. on Mathematical Methods for Curves and Surfaces, pp.55-69, 2010. ,
Global structure optimization of quadrilateral meshes, Comput. Graph. Forum, vol.30, issue.2, pp.375-384, 2011. ,
State of the art in quad meshing, Eurographics STARS, 2012. ,
Shape-up: Shaping discrete geometry with projections, Comp. Graph. Forum, vol.31, pp.5-1657, 2012. ,
Dual loops meshing: Quality quad layouts on manifolds, ACM Trans. Graph, vol.31, issue.4, 2012. ,
Seminal graphics Recursively generated B-spline surfaces on arbitrary topological meshes, pp.183-188, 1998. ,
Quadrilateral mesh simplification, SIGGRAPH Asia '08: ACM SIGGRAPH Asia 2008 papers, pp.1-9, 2008. ,
Localized Quadrilateral Coarsening, SGP '09: Proceedings of the Symposium on Geometry Processing, Eurographics Association, pp.1437-1444, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01520.x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.226.3965
Spectral surface quadrangulation, SIG- GRAPH '06: ACM SIGGRAPH 2006 Papers, pp.1057-1066, 2006. ,
Texture mapping with hard constraints, Comput. Graph. Forum, vol.20, issue.3, 2001. ,
Surface parameterization: a tutorial and survey. In Advances in Multiresolution for Geometric Modelling, Mathematics and Visualization, pp.157-186, 2005. ,
Mesh parameterization: theory and practice, SIGGRAPH '07: ACM SIGGRAPH 2007 courses, 2007. ,
Spectral quadrangulation with orientation and alignment control, ACM Trans. Graph, vol.27, issue.5, pp.1-9, 2008. ,
Quadcover -surface parameterization using branched coverings, Computer Graphics Forum, vol.26, issue.3, pp.375-384, 2007. ,
Globally smooth parameterizations with low distortion, ACM SIG- GRAPH 2003 Papers, pp.350-357, 2003. ,
Computing geodesic paths on manifolds, Proc. Natl. Acad. Sci. USA, pp.8431-8435, 1998. ,
Anisotropic quadrangulation, Proceedings of the 14th ACM Symposium on Solid and Physical Modeling, pp.137-146, 2010. ,
Meshless quadrangulation by global parametrization, Computer and Graphics, 2011. ,
All-hex meshing using singularity-restricted field, ACM Trans. Graph, vol.31, issue.177, pp.1-17711, 2012. ,
Openflipper: An open source geometry processing and rendering framework, Curves and Surfaces, pp.488-500, 2012. ,
The spatial twist continuum: A connectivity based method for representing all-hexahedral finite element meshes, Finite Element in Analysis and Design, vol.28, pp.2-137, 1997. ,
Cubecover-parameterization of 3d volumes, Comput. Graph. Forum, vol.30, issue.5, pp.1397-1406, 2011. ,
Computing geodesic distances on triangular meshes, The 10-th International Conference in Central Europe on Computer Graphics, Visualization and Computer Vision, 2002. ,
Q-morph: an indirect approach to advancing front quad meshing, International Journal for Numerical Methods in Engineering, vol.44, issue.9, pp.1317-1340, 1999. ,
Handbook of applied optimization, 2002. ,
Almost isometric mesh parameterization through abstract domains, IEEE Transaction on Visualization and Computer Graphics, vol.16, issue.4, pp.621-635, 2010. ,
Global parametrization of range image sets, Proceedings of SIGGRAPH Asia, 2006. ,
Nsymmetry direction field design, ACM Trans. Graph, vol.27, issue.2, pp.1-13, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00331900
Mesh parameterization methods and their applications, Found. Trends. Comput. Graph. Vis, vol.2, pp.105-171, 2006. ,
Conformal equivalence of triangle meshes, SIGGRAPH '08: ACM SIGGRAPH 2008 papers, pp.1-11, 2008. ,
Practical quad mesh simplification, Computer Graphics Forum Conference ), vol.29, issue.2, pp.407-418, 2010. ,
Simple quad domains for field aligned mesh parametrization, Proceedings of SIGGRAPH Asia, 2006. ,
Designing quadrangulations with discrete harmonic forms, Proc. of SGP, EG Association, pp.6-201, 2006. ,
On the implementation of an interior-point filter line-search algorithm for large-scale nonlinear programming, Mathematical Programming, vol.10, issue.1, pp.25-57, 2006. ,
DOI : 10.1007/s10107-004-0559-y
Computing extremal quasiconformal maps, Comp. Graph. Forum, vol.31, issue.5, pp.1679-1689, 2012. ,
An rbf-based reparameterization method for constrained texture mapping, IEEE Transactions on Visualization and Computer Graphics, vol.18, issue.7, pp.1115-1124, 2012. ,
A wavebased anisotropic quadrangulation method, ACM Trans. Graph, vol.29, issue.118, pp.1-118, 2010. ,
