How to Compute the Area of a Triangle: a Formal Revisit with a Tighter Error Bound - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Mathematical values are usually computed using well-known mathematical formulas without thinking about their accuracy, which may turn awful with particular instances. This is the case for the computation of the area of a triangle. When the triangle is needle-like, the common formula has a very poor accuracy. Kahan proposed in 1986 an algorithm he claimed correct within a few ulps. Goldberg took over this algorithm in 1991 and gave a precise error bound. This article presents a formal proof of this algorithm, investigations in case of underflow and a new improvement of its error bound.
article.pdf (273.04 Ko) Télécharger le fichier
hal-00862653 , version 1 (17-09-2013)
  • HAL Id : hal-00862653 , version 1
Sylvie Boldo. How to Compute the Area of a Triangle: a Formal Revisit with a Tighter Error Bound. 2013. ⟨hal-00862653⟩
179 Consultations
254 Téléchargements
