VEGTER c 2013 The Author(s) c 2013 The Eurographics Association and ,
A simple algorithm for homeomorphic surface reconstruction, In SoCG, issue.2, pp.213-222, 2000. ,
Voronoi-based variational reconstruction of unoriented point sets, In SGP, issue.2, pp.39-48, 2007. ,
Point set processing, 2013. ,
An experimental comparison of min-cut/max-flow algorithms for energy minimization in vision, PAMI, vol.26, issue.9 8, pp.1124-1137, 2004. ,
Geometric structures for threedimensional shape representation, ACM Trans. Graph, vol.3, issue.4, pp.266-286, 1984. ,
Reconstruction and representation of 3D objects with radial basis functions, SIGGRAPH, pp.67-76, 2001. ,
Robust piecewise-planar 3D reconstruction and completion from largescale unstructured point data, CVPR, pp.1261-1268, 2010. ,
Algorithm for solution of a problem of maximum flow in networks with power estimation, Soviet Mathematics Doklady, vol.11, issue.8, pp.1277-1280, 1970. ,
On the shape of a set of points in the plane, In IEEE Trans. Inf. Th, vol.29, issue.2, pp.551-559, 1983. ,
A new approach to the maximum-flow problem, J. ACM, vol.35, issue.4 8, pp.921-940, 1988. ,
Robust and efficient surface reconstruction from range data, Comp. Graph. Forum, vol.28, issue.10, pp.2275-2290, 2009. ,
Signing the Unsigned: Robust Surface Reconstruction from Raw Pointsets, Computer Graphics Forum, vol.2005, issue.5, pp.1733-1741, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01782.x
Control volume meshes using sphere packing, IMR, pp.47-61, 1996. ,
DOI : 10.1007/BFb0018533
Completion and reconstruction with primitive shapes, Comp. Graph. Forum, vol.28, issue.2, pp.503-512, 2009. ,
Meshing piecewise linear complexes by constrained Delaunay tetrahedralizations, IMR (2005), pp.147-163 ,
A condition guaranteeing the existence of higher-dimensional constrained delaunay triangulations, SoCG, pp.76-85, 1998. ,
Constrained Delaunay tetrahedralizations and provably good boundary recovery, IMR, pp.193-204, 2002. ,
Updating and constructing constrained Delaunay and constrained regular triangulations by flips, SoCG, pp.181-190, 2003. ,
Interpolating and approximating implicit surfaces from polygon soup ,
Cone carving for surface reconstruction, ACM Trans. Graph, vol.29, issue.150 2, pp.1-15010, 2010. ,
Efficient RANSAC for point-cloud shape detection, Comp. Graph. Forum, vol.26, issue.2 2, pp.214-226, 2007. ,
Houghtransform and extended RANSAC algorithms for automatic detection of 3D building roof planes from lidar data, In IAPRS, vol.36, issue.2, 2007. ,
Surface reconstruction from LiDAR data with extended snake theory, EMMCVPR '07, pp.479-492, 2007. ,
On the shape of a set of points and lines in the plane, Watertight Scenes from Urban LiDAR and Planar Surfaces. Tech. Rep. UU-CS-2013-007, pp.1553-1562, 2011. ,
DOI : 10.1111/j.1467-8659.2011.02029.x
