The Discrete Geometric Conservation Law and the Nonlinear Stability of ALE Schemes for the Solution of Flow Problems on Moving Grids, Journal of Computational Physics, vol.174, issue.2, pp.669-694, 2000. ,
DOI : 10.1006/jcph.2001.6932
A multiple grid scheme for solving the Euler equations, 5th Computational Fluid Dynamics Conference, pp.1565-1571, 1981. ,
DOI : 10.2514/6.1981-1025
A monotone streamline upwind finite element method for convection-dominated flows, Computer Methods in Applied Mechanics and Engineering, vol.48, issue.3, pp.313-327, 1985. ,
DOI : 10.1016/S0045-7825(85)80005-0
Streamline upwind/Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.32, issue.1-3, pp.199-259, 1982. ,
DOI : 10.1016/0045-7825(82)90071-8
Fluctuations and signals -a framework for numerical evolution problems, Numerical Methods for Fluids Dynamics, pp.219-257, 1982. ,
Linear advection schemes on triangular meshes, 1987. ,
An arbitrary lagrangian eulerian formulation for residual distribution schemes on moving grids. Computers and Fluids, pp.59-71, 2001. ,
Numerical Algorithms for the Computation of Steady and Unsteady Compressible Flow over Moving Geometries -Application to Fluid-Structure Interaction, 2007. ,
Explicit Runge???Kutta residual distribution schemes for time dependent problems: Second order case, Journal of Computational Physics, vol.229, issue.16, pp.5653-5691, 2010. ,
DOI : 10.1016/j.jcp.2010.04.002
URL : https://hal.archives-ouvertes.fr/inria-00406958
Multidimensional upwinding: Its relation to finite elements, International Journal for Numerical Methods in Fluids, vol.II, issue.8-9, pp.935-955, 1995. ,
DOI : 10.1002/fld.1650200815
Improving time accuracy of residual distribution schemes, 1996. ,
Solution of the unsteady Euler equations using residual distribution and flux corrected transport, 1997. ,
Construction of second order accurate monotone and stable residual distribution schemes for unsteady flow problems, Journal of Computational Physics, vol.188, issue.1, pp.16-55, 2003. ,
DOI : 10.1016/S0021-9991(03)00084-6
Residual Distribution Schemes for Conservation Laws via Adaptive Quadrature, SIAM Journal on Scientific Computing, vol.24, issue.3, pp.732-769, 2002. ,
DOI : 10.1137/S106482750138592X
A Conservative Formulation of the Multidimensional Upwind Residual Distribution Schemes for General Nonlinear Conservation Laws, Journal of Computational Physics, vol.179, issue.1, pp.286-312, 2002. ,
DOI : 10.1006/jcph.2002.7057
URL : https://hal.archives-ouvertes.fr/hal-00402585
Residual distribution for general time-dependent conservation laws, Journal of Computational Physics, vol.209, issue.1, pp.249-289, 2005. ,
DOI : 10.1016/j.jcp.2005.03.003
URL : https://hal.archives-ouvertes.fr/hal-00402584
Progress on multidimensional upwind Euler solvers for unstructured grids, 10th Computational Fluid Dynamics Conference, 1991. ,
DOI : 10.2514/6.1991-1550
Comparison of solution accuracy of multidimensional residual distribution and Godunov-type finite-volume methods, International Journal of Computational Fluid Dynamics, vol.47, issue.1-2, pp.61-83, 2008. ,
DOI : 10.1006/jcph.1999.6281
Multigrid solution of monotone second-order discretizations of hyperbolic conservation laws, Mathematics of Computation, vol.49, issue.179, pp.135-155, 1987. ,
DOI : 10.1090/S0025-5718-1987-0890258-9
Numerical methods for conservation laws on structured and unstructured meshes, VKI LS 2003-05, 33 rd Computational Fluid dynamics Course, von Karman Institute for Fluid Dynamics, 2003. ,
Finite Volume Methods: Foundation and Analysis, Encyclopedia of Computational Mechanics, 2004. ,
DOI : 10.1002/0470091355.ecm010
Residual Distribution Schemes: Foundations and Analysis, Encyclopedia of Computational Mechanics, 2007. ,
DOI : 10.1002/0470091355.ecm054
URL : https://hal.archives-ouvertes.fr/hal-00402592
High-order fluctuation schemes on triangular meshes, Journal of Scientific Computing, vol.19, issue.1/3, pp.3-36, 2003. ,
DOI : 10.1023/A:1025335421202
Application of conservative residual distribution schemes to the solution of the shallow water equations on unstructured meshes, Journal of Computational Physics, vol.222, issue.1, pp.287-331, 2007. ,
DOI : 10.1016/j.jcp.2006.06.024
URL : https://hal.archives-ouvertes.fr/inria-00402649
A finite difference method for the numerical computation of discontinuous solutions of the equations of fluid dynamics, Mat. Sb, vol.47, 1959. ,
Compact cell vertex convection schemes on unstructured meshes, Notes on Numerical Fluid Mechanics, pp.1-50, 1997. ,
Status of multidimensional upwind residual distribution schemes and applications in aeronautics, Fluids 2000 Conference and Exhibit, 2000. ,
DOI : 10.2514/6.2000-2328
Construction of second-order accurate monotone and stable residual distribution schemes for steady problems, Journal of Computational Physics, vol.195, issue.2, pp.474-507, 2004. ,
DOI : 10.1016/j.jcp.2003.09.022
A second-order-accurate monotone implicit fluctuation splitting scheme for unsteady problems, Journal of Computational Physics, vol.208, issue.1, pp.1-33, 2005. ,
DOI : 10.1016/j.jcp.2004.11.023
Stabilized residual distribution for shallow water simulations, Journal of Computational Physics, vol.228, issue.4, pp.1071-1115, 2009. ,
DOI : 10.1016/j.jcp.2008.10.020
URL : https://hal.archives-ouvertes.fr/inria-00538892
Discontinuous upwind residual distribution: A route to unconditional positivity and high order accuracy, Computers & Fluids, vol.46, issue.1, pp.263-269, 2011. ,
DOI : 10.1016/j.compfluid.2010.12.023
URL : https://hal.archives-ouvertes.fr/hal-00652403
Unconditionally stable space-time discontinuous residual distribution for shallow-water flows, J.Comput.Phys ,
URL : https://hal.archives-ouvertes.fr/hal-00869272
Conservation de la positivité lors de la discétization des problèmes d'èvolution paraboliques, R.A.I.R.O. Analyse Numèrique, vol.12, pp.237-254, 1978. ,
Improving monotonicity of the 2nd order backward difference time integration scheme by temporal limiting, Computational Fluid Dynamics, pp.733-738, 2008. ,
Higher Order Triangular Finite Elements with Mass Lumping for the Wave Equation, SIAM Journal on Numerical Analysis, vol.38, issue.6, pp.2047-2078, 2001. ,
DOI : 10.1137/S0036142997329554
URL : https://hal.archives-ouvertes.fr/hal-01010373
Geometric conservation laws for flow problems with moving boundaries and deformable meshes, and their impact on aeroelastic computations, Computer Methods in Applied Mechanics and Engineering, vol.134, issue.1-2, pp.71-90, 1996. ,
DOI : 10.1016/0045-7825(96)01028-6
Second order blended multidimensional upwind residual distribution scheme for steady and unsteady computations, Journal of Computational and Applied Mathematics, vol.215, issue.2, pp.378-389, 2006. ,
DOI : 10.1016/j.cam.2006.03.046
An Interpolation Free Two-Dimensional Conservative ALE scheme over Adaptive Unstructured Grids for Rotorcraf Aerodynamics, 2012. ,
