A simple algorithm for homeomorphic surface reconstruction, Proceedings of the sixteenth annual symposium on Computational geometry, SCG'00, pp.213-222, 2000. ,
The power crust, Proceedings of the sixth ACM symposium on Solid modeling and applications , SMA '01, pp.249-266, 2001. ,
DOI : 10.1145/376957.376986
The ball-pivoting algorithm for surface reconstruction, IEEE Transactions on Visualization and Computer Graphics, vol.5, issue.4, pp.349-359, 1999. ,
DOI : 10.1109/2945.817351
Scale Space Meshing of Raw Data Point Sets, Computer Graphics Forum, vol.5, issue.9, pp.1630-1642, 2011. ,
DOI : 10.1111/j.1467-8659.2011.01848.x
Spectral surface reconstruction from noisy point clouds, Proceedings of the 2004 Eurographics/ACM SIGGRAPH symposium on Geometry processing , SGP '04, pp.11-21, 2004. ,
DOI : 10.1145/1057432.1057434
Robust and Efficient Surface Reconstruction From Range Data, Computer Graphics Forum, vol.1, issue.4 ,
DOI : 10.1111/j.1467-8659.2009.01530.x
URL : https://hal.archives-ouvertes.fr/hal-00712261
Marching cubes: A high resolution 3D surface construction algorithm, ACM SIGGRAPH Computer Graphics, vol.21, issue.4, pp.163-169, 1987. ,
DOI : 10.1145/37402.37422
Surface reconstruction from unorganized points, ACM SIGGRAPH Computer Graphics, vol.26, issue.2, pp.71-78, 1992. ,
DOI : 10.1145/142920.134011
A volumetric method for building complex models from range images, Proceedings of the 23rd annual conference on Computer graphics and interactive techniques , SIGGRAPH '96, pp.303-312, 1996. ,
DOI : 10.1145/237170.237269
Fast surface reconstruction using the level set method, Proceedings of the IEEE Workshop on Variational and Level Set Methods (VLSM'01), VLSM'01, p.194, 2001. ,
Robust reconstruction of watertight 3D models from non-uniformly sampled point clouds without normal information, Proceedings of the fourth Eurographics symposium on Geometry processing, pp.41-50, 2006. ,
Reconstruction and representation of 3D objects with radial basis functions, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, pp.67-76, 2001. ,
DOI : 10.1145/383259.383266
3D scattered data approximation with adaptive compactly supported radial basis functions, Proceedings Shape Modeling Applications, 2004., pp.31-39, 2004. ,
DOI : 10.1109/SMI.2004.1314491
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.61.3544
Poisson surface reconstruction, Proceedings of the fourth Eurographics symposium on Geometry processing, SGP'06, Eurographics Association, pp.61-70, 2006. ,
Mesh-independent surface interpolation, Geometric Modeling for Scientific Visualization, pp.37-49, 2003. ,
Computing and rendering point set surfaces, IEEE Transactions on Visualization and Computer Graphics, vol.9, issue.1, pp.3-15, 2003. ,
DOI : 10.1109/TVCG.2003.1175093
Algebraic point set surfaces, ACM Trans.Graph, vol.26, issue.23, pp.1-23, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00354998
Feature Preserving Point Set Surfaces based on Non-Linear Kernel Regression, Computer Graphics Forum, vol.16, issue.2, pp.493-501, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01388.x
URL : https://hal.archives-ouvertes.fr/inria-00354969
Signing the Unsigned: Robust Surface Reconstruction from Raw Pointsets, Computer Graphics Forum, vol.2005, issue.5, pp.1733-1741, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01782.x
URL : https://hal.archives-ouvertes.fr/inria-00502473
Random sample consensus: a paradigm for model fitting with applications to image analysis and automated cartography, Communications of the ACM, vol.24, issue.6, pp.381-395, 1981. ,
DOI : 10.1145/358669.358692
Efficient RANSAC for Point-Cloud Shape Detection, Computer Graphics Forum, vol.57, issue.2, pp.214-226, 2007. ,
DOI : 10.1016/S0010-4485(96)00054-1
Estimating surface normals in noisy point cloud data, in: special issue of, International Journal of Computational Geometry and Applications, vol.14, pp.4-5, 2004. ,
Surface reconstruction by voronoi filtering, Proceedings of the fourteenth annual symposium on Computational geometry , SCG'98, pp.39-48, 1998. ,
DOI : 10.1007/pl00009475
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.71
An adaptive mls surface for reconstruction with guarantees, Proceedings of the third EUROGRAPHICS symposium on Geometry processing, SGP'05, pp.43-52, 2005. ,
Voronoi-based variational reconstruction of unoriented point sets, Proceedings of the fifth Eurographics symposium on Geometry processing, pp.39-48, 2007. ,
Robust normal estimation for point clouds with sharp features, Computers & Graphics, vol.34, issue.2, pp.94-106, 2010. ,
DOI : 10.1016/j.cag.2010.01.004
Provably good sampling and meshing of surfaces, Graphical Models, vol.67, issue.5, pp.405-451, 2005. ,
DOI : 10.1016/j.gmod.2005.01.004
URL : https://hal.archives-ouvertes.fr/hal-00488829
Estimating differential quantities using polynomial fitting of osculating jets, Proceedings of the 2003 Eurographics, pp.177-187, 2003. ,
DOI : 10.1016/j.cagd.2004.09.004
URL : https://hal.archives-ouvertes.fr/hal-00103047
Point set surfaces, Proceedings Visualization, 2001. VIS '01., pp.21-28, 2001. ,
DOI : 10.1109/VISUAL.2001.964489
Multiple View Geometry in Computer Vision, 2004. ,
DOI : 10.1017/CBO9780511811685
Surface reconstruction from multi-view stereo, Proceedings of the 9th Asian Conference on Computer Vision, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00422344
Practical ray tracing in C, Computer-Aided Design, vol.25, issue.10, 1992. ,
DOI : 10.1016/0010-4485(93)90024-I
Provable surface reconstruction from noisy samples, Computational Geometry, vol.35, issue.1-2, pp.124-141, 2006. ,
DOI : 10.1016/j.comgeo.2005.10.006
Multi-level partition of unity implicits, ACM Trans.Graph, vol.22, issue.3, pp.463-470, 2003. ,
