New interface
Conference papers
Proved Generation of Implementations from Computationally-Secure Protocol Specifications
Abstract : In order to obtain implementations of security protocols proved secure in the computational model, we have previously implemented a compiler that takes a specification of the protocol in the input language of the computational protocol verifier CryptoVerif and translates it into an OCaml implementation. However, until now, this compiler was not proved correct, so we did not have real guarantees on the generated implementation. In this paper, we fill this gap. We prove that this compiler preserves the security properties proved by CryptoVerif: if an adversary has probability p of breaking a security property in the generated code, then there exists an adversary that breaks the property with the same probability p in the CryptoVerif specification. Therefore, if the protocol specification is proved secure in the computational model by CryptoVerif, then the generated implementation is also secure.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00863376
Contributor : Ben Smyth Connect in order to contact the contributor
Submitted on : Wednesday, September 18, 2013 - 5:37:08 PM
Last modification on : Friday, January 21, 2022 - 3:19:26 AM
Identifiers
  • HAL Id : hal-00863376, version 1
Collections
Citation
David Cadé, Bruno Blanchet. Proved Generation of Implementations from Computationally-Secure Protocol Specifications. 2nd Conference on Principles of Security and Trust (POST 2013), 2013, Rome, Italy. pp.63--82. ⟨hal-00863376⟩
Share
Metrics
Record views
57
