Reports
High-Dimensional Regression with Gaussian Mixtures and Partially-Latent Response Variables
Antoine Deleforge 1 Florence Forbes 2 Radu Horaud 1
1 PERCEPTION - Interpretation and Modelling of Images and Videos
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
2 MISTIS - Modelling and Inference of Complex and Structured Stochastic Systems
Abstract : In this work we address the problem of approximating high-dimensional data with a low-dimensional representation. We make the following contributions. We propose an inverse regression method which exchanges the roles of input and response, such that the low-dimensional variable becomes the regressor, and which is tractable. We introduce a mixture of locally-linear probabilistic mapping model that starts with estimating the parameters of inverse regression, and follows with inferring closed-form solutions for the forward parameters of the high-dimensional regression problem of interest. Moreover, we introduce a partially-latent paradigm, such that the vector-valued response variable is composed of both observed and latent entries, thus being able to deal with data contaminated by experimental artifacts that cannot be explained with noise models. The proposed probabilistic formulation could be viewed as a latent-variable augmentation of regression. We devise expectation-maximization (EM) procedures based on a data augmentation strategy which facilitates the maximum-likelihood search over the model parameters. We propose two augmentation schemes and we describe in detail the associated EM inference procedures that may well be viewed as generalizations of a number of EM regression, dimension reduction, and factor analysis algorithms. The proposed framework is validated with both synthetic and real data. We provide experimental evidence that our method outperforms several existing regression techniques.
Complete list of metadatas
https://hal.inria.fr/hal-00863468
Contributor : Team Perception <>
Submitted on : Thursday, January 9, 2014 - 5:31:49 PM
Last modification on : Tuesday, November 24, 2020 - 4:38:03 PM
Long-term archiving on: : Thursday, April 10, 2014 - 12:00:52 PM
File
submission_rev.pdf
Identifiers
  • HAL Id : hal-00863468, version 2
Citation
Antoine Deleforge, Florence Forbes, Radu Horaud. High-Dimensional Regression with Gaussian Mixtures and Partially-Latent Response Variables. [Research Report] 2013, pp.arXiv:1308.2302. ⟨hal-00863468v2⟩
Share
Metrics
Record views
59
Files downloads
81
