Abstract : We present an automatic, language-independent program verification approach and prototype tool based on symbolic execution. The program-specification formalism we consider is Reachability Logic, a language-independent alternative to Hoare logics. Reachability Logic has a sound and relatively complete deduction system that offers a lot of freedom to the user regarding the manner and order of rule application, but it lacks a strategy for automatic proof construction. Hence, we propose a procedure for proof construction, in which symbolic execution plays a major role. We prove that, under reasonable conditions on its inputs (the operational semantics of a programming language, and a specification of a program, both given as sets of Reachability Logic formulas) our procedure is partially correct: if it terminates it correctly answers (positively or negatively) to the question of whether the given program specification holds when executing the program according to the given semantics. Termination, of course, cannot be guaranteed, since program-verification is an undecidable problem; but it does happen if the provided set of goals includes enough information in order to be circularly provable (using each other as hypotheses). We introduce a prototype program-verification tool implementing our procedure in the K language-definition framework, and illustrate it by verifying nontrivial programs written in languages defined in K
Résumé : Nous présentons une méthode automatique pour vérifier des programmes, qui ne dépend pas du langage de programmation dans lequel les programmes à vérifier sont écrits. Pour cela nous nous appuyons sur la Reachability Logic, un formalisme de spécification introduit récemment, qui peut être vu comme une alternative à la logique de Hoare, mais qui, contrairement à cette dernière, ne dépend pas du langage de programmation utilisé. La Reachability Logic est munie d'un système déductif correct et relativement complet, qui laisse beaucoup de liberté à l'utilisateur sur la manière d'appliquer les règles de déduction, mais qui n'offre pas de stratégie pour construire automatiquement des preuves. Par conséquent nous proposons ici une procédure de construction des preuves, dans laquelle l'exécution symbolique joue un rôle essentiel. Nous montrons que, moyennant des conditions raisonnables sur la sémantique des langages de programmation et sur les propriétés des programmes, notre procédure est partiellement correcte. Ceci dit en substance que, lorsqu'elle termine, la procédure résout correctement le problème de vérification de programmes à base de Reachability Logic. La terminaison ne peut être garantie car la vérification de programmes est indécidable, mais la procédure termine lorsque les propriétés contiennent suffisamment d'information pour être prouvées de manière circulaire, en s'utilisant mutuellement comme hypothèses. Nous présentons une implémentation prototype d'un outil de vérification basé sur ces idées, que nous avons implémenté dans la K framework et que nous illustrons sur des exemples de programmes non triviaux, écrits dans des langages formellement définis en K.
