Toward the Ultimate Conservative Scheme: Following the Quest, Journal of Computational Physics, vol.167, issue.2, pp.277-315, 2001. ,
DOI : 10.1006/jcph.2000.6672
A residual distribution method using discontinuous elements for the computation of possibly non smooth flows, Adv. in Appl. Math. Mech, vol.2, issue.1, pp.32-44, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00535815
Status of multidimensional upwind residual distribution schemes and applications in aeronautics, 2000. ,
Construction of second order accurate monotone and stable residual distribution schemes for unsteady flow problems, Journal of Computational Physics, vol.188, issue.1, pp.16-55, 2003. ,
DOI : 10.1016/S0021-9991(03)00084-6
Residual distribution schemes for steady problems, Computational Fluid Dynamics, VKI LS 2003-05. von Karman Institute for Fluid Dynamics, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00652412
PETSc users manual, 2012. ,
Streamline upwind/Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.32, issue.1-3, pp.1-3, 1982. ,
DOI : 10.1016/0045-7825(82)90071-8
Compact Third-Order Multidimensional Upwind Scheme for Navier-Stokes Simulations, Theoretical and Computational Fluid Dynamics, vol.15, issue.6, pp.373-401, 2002. ,
DOI : 10.1007/s00162-002-0060-2
Multidimensional upwinding: Its relation to finite elements, International Journal for Numerical Methods in Fluids, vol.II, issue.8-9, pp.935-955, 1995. ,
DOI : 10.1002/fld.1650200815
The Runge???Kutta Discontinuous Galerkin Method for Conservation Laws V, Journal of Computational Physics, vol.141, issue.2, pp.199-224, 1998. ,
DOI : 10.1006/jcph.1998.5892
Space-time residual distribution schemes for hyperbolic conservation laws on unstructured linear finite elements, Internat. J. Numer. Methods Fluids, vol.40, pp.3-4, 2002. ,
Residual distribution for general time-dependent conservation laws, J. Comput. Phys, vol.209, issue.1, pp.249-289, 2005. ,
Space-time residual distribution schemes for hyperbolic conservation laws, 15th AIAA Computational Fluid Dynamics Conference, 2001. ,
DOI : 10.2514/6.2001-2617
A Conservative Formulation of the Multidimensional Upwind Residual Distribution Schemes for General Nonlinear Conservation Laws, Journal of Computational Physics, vol.179, issue.1, pp.286-312, 2002. ,
DOI : 10.1006/jcph.2002.7057
A second-order-accurate monotone implicit fluctuation splitting scheme for unsteady problems, Journal of Computational Physics, vol.208, issue.1, pp.1-33, 2005. ,
DOI : 10.1016/j.jcp.2004.11.023
Upwind methods and multidimensional splittings for the Euler equations, Computational Fluid Dynamics, VKI LS 1991-01. von Karman Institute for Fluid Dynamics, 1991. ,
Solution of the unsteady Euler equations using residual distribution and flux corrected transport, 1997. ,
Residual Distribution Schemes: Foundations and Analysis, Encyclopedia of Computational Mechanics, 2007. ,
DOI : 10.1002/0470091355.ecm054
URL : https://hal.archives-ouvertes.fr/hal-00402592
A multidimensional generalization of Roe's flux difference splitter for the euler equations, Computers & Fluids, vol.22, issue.2-3, pp.215-222, 1993. ,
DOI : 10.1016/0045-7930(93)90053-C
Second order blended multidimensional upwind residual distribution scheme for steady and unsteady computations, Journal of Computational and Applied Mathematics, vol.215, issue.2, pp.378-389, 2008. ,
DOI : 10.1016/j.cam.2006.03.046
An evaluation of several differencing methods for inviscid fluid flow problems, Journal of Computational Physics, vol.2, issue.3, pp.306-331, 1968. ,
DOI : 10.1016/0021-9991(68)90060-0
Numerical approximation of hyperbolic systems of conservation laws, Applied Mathematical Sciences, vol.118, 1996. ,
DOI : 10.1007/978-1-4612-0713-9
Comparison of solution accuracy of multidimensional residual distribution and Godunov-type finite-volume methods, International Journal of Computational Fluid Dynamics, vol.47, issue.1-2, pp.61-83, 2008. ,
DOI : 10.1006/jcph.1999.6281
Discontinuous fluctuation distribution, ICFD 2010 International Conference on Fluid Dynamics, 2010. ,
DOI : 10.1016/j.jcp.2008.08.017
URL : https://hal.archives-ouvertes.fr/inria-00522477
Discontinuous fluctuation distribution, Journal of Computational Physics, vol.227, issue.24, pp.125-10147, 2008. ,
A framework for discontinuous fluctuation distribution, International Journal for Numerical Methods in Fluids, vol.43, issue.8, pp.1305-1311, 2008. ,
DOI : 10.1002/fld.1726
A new finite element formulation for computational fluid dynamics: III. The generalized streamline operator for multidimensional advective-diffusive systems, Computer Methods in Applied Mechanics and Engineering, vol.58, issue.3, pp.305-328, 1986. ,
DOI : 10.1016/0045-7825(86)90152-0
Numerical solution of partial differential equations by the finite element method, 2009. ,
Numerical methods for conservation laws, second edn, Lectures in Mathematics ETH Zürich. Birkhäuser Verlag, 1992. ,
Finite volume methods for hyperbolic problems. Cambridge Texts in Applied Mathematics, 2002. ,
Improving time accuracy of residual distribution schemes, 1996. ,
Explicit Runge???Kutta residual distribution schemes for time dependent problems: Second order case, Journal of Computational Physics, vol.229, issue.16, pp.5653-5691, 2010. ,
DOI : 10.1016/j.jcp.2010.04.002
URL : https://hal.archives-ouvertes.fr/inria-00406958
Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-372, 1981. ,
DOI : 10.1016/0021-9991(81)90128-5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.457.5978
Fluctuations and signals -a framework for numerical evolution problems In: Numerical Methods for Fluid Dynamics, pp.219-257, 1982. ,
Linear advection schemes on triangular meshes, 1987. ,
Efficient implementation of essentially nonoscillatory shock-capturing schemes Fluctuation splitting schemes for the 2D Euler equations, Computational Fluid Dynamics, VKI LS 1991-01. von Karman Institute for Fluid Dynamics, pp.439-471, 1988. ,
Discontinuous residual distribution schemes for time-dependent problems, ) Recent Advances In Scientific Computing And Applications , Contemporary Mathematics, pp.375-382, 2013. ,
DOI : 10.1090/conm/586/11647
Positive matrix distribution schemes for hyperbolic systems, with application to the Euler equations, Computational Fluid Dynamics '96, pp.747-753, 1996. ,
A parallel, implicit, multi-dimensional upwind, residual distribution method for the Navier-Stokes equations on unstructured grids, Computational Mechanics, vol.23, issue.2, pp.199-208, 1999. ,
DOI : 10.1007/s004660050401
The numerical simulation of two-dimensional fluid flow with strong shocks, Journal of Computational Physics, vol.54, issue.1, pp.115-173, 1984. ,
DOI : 10.1016/0021-9991(84)90142-6
