Structured design, IBM Systems Journal, vol.13, issue.2, pp.115-139, 1974. ,
DOI : 10.1147/sj.132.0115
Service-oriented design and development methodology, International Journal of Web Engineering and Technology, vol.2, issue.4, pp.412-442, 2006. ,
DOI : 10.1504/IJWET.2006.010423
Design Principles for B2B Services - An Evaluation of Two Alternative Service Designs, IEEE International Conference on Services Computing (SCC 2007), pp.372-379, 2007. ,
DOI : 10.1109/SCC.2007.50
Identification and Analysis of Business and Software Services -A Consolidated Apporach, IEEE Transactions on Services Computing, vol.2, issue.1, pp.1-15, 2009. ,
The Impact of Service Cohesion on the Analyzability of Service-Oriented Software, IEEE Transactions on Services Computing, vol.3, issue.2, pp.89-103, 2010. ,
DOI : 10.1109/TSC.2010.23
Fine-Grained Metrics of Cohesion Lack for Service Interfaces, 2011 IEEE International Conference on Web Services, pp.588-595, 2011. ,
DOI : 10.1109/ICWS.2011.27
URL : https://hal.archives-ouvertes.fr/inria-00574182
Identification of Move Method Refactoring Opportunities, IEEE Transactions on Software Engineering, vol.35, issue.3, pp.347-367, 2009. ,
DOI : 10.1109/TSE.2009.1
Metrics based refactoring, Proceedings Fifth European Conference on Software Maintenance and Reengineering, pp.30-39, 2001. ,
DOI : 10.1109/CSMR.2001.914965
Decomposing object-oriented class modules using an agglomerative clustering technique, 2009 IEEE International Conference on Software Maintenance, pp.93-101, 2009. ,
DOI : 10.1109/ICSM.2009.5306332
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.157.8450
Automatic clustering of software systems using a genetic algorithm, STEP '99. Proceedings Ninth International Workshop Software Technology and Engineering Practice, pp.73-81, 1999. ,
DOI : 10.1109/STEP.1999.798481
Refactoring: Improving Coupling and Cohesion of Existing Code, Proceedings of the 11th IEEE Working Conference on Reverse Engineering (WCRE), pp.144-151, 2004. ,
Search-based determination of refactorings for improving the class structure of object-oriented systems, Proceedings of the 8th annual conference on Genetic and evolutionary computation , GECCO '06, pp.1909-1916, 2006. ,
DOI : 10.1145/1143997.1144315
Improving Design Quality Using Meta-Pattern Transformations: A Metric-Based Approach Search-Based Refactoring for Software Maintenance, Journal of Software Maintenance Journal of Systems and Software, vol.16, issue.81 4, pp.331-361, 2004. ,
Solving the Class Responsibility Assignment Problem in Object-Oriented Analysis with Multi-Objective Genetic Algorithms, IEEE Transactions on Software Engineering, vol.36, issue.6, pp.817-837, 2010. ,
DOI : 10.1109/TSE.2010.70
Refactoring Object-Oriented Frameworks, 1992. ,
Automated support for program refactoring using invariants, Proceedings IEEE International Conference on Software Maintenance. ICSM 2001, pp.736-746, 2001. ,
DOI : 10.1109/ICSM.2001.972794
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.9217
Binary refactoring, Proceedings of the 27th international conference on Software engineering , ICSE '05, pp.264-273, 2005. ,
DOI : 10.1145/1062455.1062511
From C++ Refactorings to Graph Transformations, Proceedings of the 3rd Workshop on Software Evolution through Transformations, 2006. ,
Automated Detection of Refactorings in Evolving Components, Proceedings of 20th European Conference on Object-Oriented Programming, pp.404-428, 2006. ,
DOI : 10.1007/11785477_24
Automated Inference of Pointcuts in Aspect-Oriented Refactoring, 29th International Conference on Software Engineering (ICSE'07), pp.127-136, 2007. ,
DOI : 10.1109/ICSE.2007.19
Tool-Supported Refactoring of Existing Object-Oriented Code into Aspects, IEEE Transactions on Software Engineering, vol.32, issue.9, pp.698-717, 2006. ,
DOI : 10.1109/TSE.2006.95
A survey of software refactoring, IEEE Transactions on Software Engineering, vol.30, issue.2, pp.126-139, 2004. ,
DOI : 10.1109/TSE.2004.1265817
Pareto optimal search based refactoring at the design level, Proceedings of the 9th annual conference on Genetic and evolutionary computation , GECCO '07, pp.1106-1113, 2007. ,
DOI : 10.1145/1276958.1277176
A metrics suite for object oriented design, IEEE Transactions on Software Engineering, vol.20, issue.6, pp.476-493, 1994. ,
DOI : 10.1109/32.295895
Search-based software engineering, Information and Software Technology, vol.43, issue.14, pp.833-839, 2001. ,
DOI : 10.1016/S0950-5849(01)00189-6
Reformulating software engineering as a search problem, IEE Proceedings - Software, vol.150, issue.3, pp.161-175, 2003. ,
DOI : 10.1049/ip-sen:20030559
A unified framework for cohesion measurement in object-oriented systems, Proceedings Fourth International Software Metrics Symposium, pp.65-117, 1998. ,
DOI : 10.1109/METRIC.1997.637164
A Precise Method-Method Interaction-Based Cohesion Metric for Object-Oriented Classes, ACM Transactions on Software Engineering and Methodology, vol.21, issue.2, 2012. ,
DOI : 10.1145/2089116.2089118
An Information Retrieval Based Approach for Measuring Service Conceptual Cohesion, 2011 11th International Conference on Quality Software, pp.102-111 ,
DOI : 10.1109/QSIC.2011.24
Property-based software engineering measurement, IEEE Transactions on Software Engineering, vol.22, issue.1, pp.68-86, 1996. ,
DOI : 10.1109/32.481535
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.25
Experimental and Quasi-Experimental Designs for Generalized Causal Inference, Houghten Mifflin, 2002. ,
An Empirical Study on Web Service Evolution, 2011 IEEE International Conference on Web Services, pp.49-56, 2011. ,
DOI : 10.1109/ICWS.2011.114
