PID controllers: Theory, Design and Tuning, 1995. ,
Finite-time stability of homogeneous systems, Proceedings of the 1997 American Control Conference (Cat. No.97CH36041), 1997. ,
DOI : 10.1109/ACC.1997.609245
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals, and Systems, vol.17, issue.2, pp.101-127, 2005. ,
DOI : 10.1007/s00498-005-0151-x
Experimental Comparison of Position Tracking Control Algorithms for Pneumatic Cylinder Actuators, IEEE/ASME Transactions on Mechatronics, vol.12, issue.5, pp.557-561, 2007. ,
DOI : 10.1109/TMECH.2007.905718
A new model for control of systems with friction, IEEE Transactions on Automatic Control, vol.40, issue.3, pp.419-425, 1995. ,
DOI : 10.1109/9.376053
Friction induced hunting limit cycles: A comparison between the LuGre and switch friction model, Automatica, vol.39, issue.12, pp.2131-2137, 2003. ,
DOI : 10.1016/S0005-1098(03)00234-6
Nonlinear systems, 2002. ,
Higher-order sliding modes, differentiation and output-feedback control, International Journal of Control, vol.76, issue.9-10, pp.924-941, 2003. ,
DOI : 10.1080/0020717031000099029
Experimenting and modelling the dynamics of pneumatic actuators controlled by the pulse width modulation (PWM) technique, Mechatronics, vol.15, issue.7, pp.859-881, 2005. ,
DOI : 10.1016/j.mechatronics.2005.01.003
Numerical differentiation with annihilators in noisy environment, Numerical Algorithms, vol.14, issue.12, pp.439-467, 2009. ,
DOI : 10.1007/s11075-008-9236-1
URL : https://hal.archives-ouvertes.fr/inria-00319240
Accurate Sliding-Mode Control of Pneumatic Systems Using Low-Cost Solenoid Valves, IEEE/ASME Transactions on Mechatronics, vol.12, issue.2, pp.216-219, 2007. ,
DOI : 10.1109/TMECH.2007.892821
Pressure observer-controller design for pneumatic cylinder actuators, IEEE/ASME Transactions on Mechatronics, vol.7, issue.4, pp.490-499, 2002. ,
DOI : 10.1109/TMECH.2002.805624
Nonlinear Modeling and Control of Servo Pneumatic Actuators, Trans. on control systems technology, vol.16, issue.3, pp.562-569, 2008. ,
Self-tuning control of a low-friction pneumatic actuator under the influence of gravity, IEEE Transactions on Control Systems Technology, vol.9, issue.2, pp.330-334, 2001. ,
DOI : 10.1109/87.911384
Fuzzy state feedback gain scheduling control of servo-pneumatic actuators, Control Engineering Practice, vol.12, issue.5, pp.639-650, 2004. ,
DOI : 10.1016/S0967-0661(03)00148-5
Dynamic behavior of pneumatic systems for lower extremity extenders, Proceedings 2002 IEEE International Conference on Robotics and Automation (Cat. No.02CH37292), pp.3248-3253, 2002. ,
DOI : 10.1109/ROBOT.2002.1013727
Multiple-surface sliding controller design for pneumatic servo systems, Mechatronics, vol.18, issue.9, pp.506-512, 2008. ,
DOI : 10.1016/j.mechatronics.2008.03.006
Sliding mode control in electromechanical systems, 1999. ,
A practical control strategy for servopneumatic actuator systems, Control Engineering Practice, issue.7, pp.1483-1488, 1999. ,
DOI : 10.1016/s0967-0661(99)00115-x
