New interface
Journal articles
Geometric and numerical methods in the contrast imaging problem in nuclear magnetic resonance
Bernard Bonnard 1, * Mathieu Claeys 2 Olivier Cots 3 Pierre Martinon 4, 5
* Corresponding author
2 LAAS-MAC - Équipe Méthodes et Algorithmes en Commande
LAAS - Laboratoire d'analyse et d'architecture des systèmes
3 McTAO - Mathematics for Control, Transport and Applications
CRISAM - Inria Sophia Antipolis - Méditerranée
5 Commands - Control, Optimization, Models, Methods and Applications for Nonlinear Dynamical Systems
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
Abstract : In this article, the contrast imaging problem in nuclear magnetic resonance is modeled as a Mayer problem in optimal control. The optimal solution can be found as an extremal, solution of the Maximum Principle and analyzed with the techniques of geometric control. This leads to a numerical investigation based on so-called indirect methods using the HamPath software. The results are then compared with a direct method implemented within the Bocop toolbox. Finally lmi techniques are used to estimate a global optimum.
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/hal-00867753
Contributor : Pierre Martinon Connect in order to contact the contributor
Submitted on : Friday, December 19, 2014 - 3:52:55 PM
Last modification on : Friday, November 25, 2022 - 10:12:06 AM
Long-term archiving on: : Saturday, April 15, 2017 - 11:36:37 AM
File
art.pdf
Identifiers
Citation
Bernard Bonnard, Mathieu Claeys, Olivier Cots, Pierre Martinon. Geometric and numerical methods in the contrast imaging problem in nuclear magnetic resonance. Acta Applicandae Mathematicae, 2015, 135 (1), pp.5-45. ⟨10.1007/s10440-014-9947-3⟩. ⟨hal-00867753v2⟩
Share
Metrics
Record views
716
Files downloads
651
