Space-efficient and exact de Bruijn graph representation based on a Bloom filter
Background
The de Bruijn graph data structure is widely used in next-generation sequencing (NGS). Many programs, e.g. de novo assemblers, rely on in-memory representation of this graph. However, current techniques for representing the de Bruijn graph of a human genome require a large amount of memory (≥30 GB).
Results
We propose a new encoding of the de Bruijn graph, which occupies an order of magnitude less space than current representations. The encoding is based on a Bloom filter, with an additional structure to remove critical false positives.
Conclusions
An assembly software implementing this structure, Minia, performed a complete de novo assembly of human genome short reads using 5.7 GB of memory in 23 hours.
Results
Conclusions
1748-7188-8-22.pdf (561.47 Ko)
Télécharger le fichier
1748-7188-8-22.xml (81.22 Ko)
Origin : Publisher files allowed on an open archive
Format : Other
