Unified speech and audio coding scheme for high quality at low bitrates, 2009 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.1-4, 2009. ,
DOI : 10.1109/ICASSP.2009.4959505
Handbook of blind source separation: independent component analysis and applications, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00460653
Probabilistic Modeling Paradigms for Audio Source Separation, Machine Audition: Principles, Algorithms and Systems. IGI Global, pp.162-185, 2010. ,
DOI : 10.4018/978-1-61520-919-4.ch007
URL : https://hal.archives-ouvertes.fr/inria-00544016
A General Flexible Framework for the Handling of Prior Information in Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.20, issue.4, pp.1118-1133, 2012. ,
DOI : 10.1109/TASL.2011.2172425
URL : https://hal.archives-ouvertes.fr/inria-00536917
The signal separation evaluation campaign Achievements and remaining challenges, Signal Processing, vol.92, issue.8, 1928. ,
URL : https://hal.archives-ouvertes.fr/inria-00579398
A Musically Motivated Mid-Level Representation for Pitch Estimation and Musical Audio Source Separation, IEEE Journal of Selected Topics in Signal Processing, vol.5, issue.6, pp.1180-1191, 2011. ,
DOI : 10.1109/JSTSP.2011.2158801
Separation by “humming”: User-guided sound extraction from monophonic mixtures, 2009 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.69-72, 2009. ,
DOI : 10.1109/ASPAA.2009.5346542
Multichannel nonnegative tensor factorization with structured constraints for userguided audio source separation, IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.257-260, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00564851
Score informed audio source separation using a parametric model of non-negative spectrogram, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), 2011. ,
DOI : 10.1109/ICASSP.2011.5946324
URL : https://hal.archives-ouvertes.fr/hal-00945294
A Watermarking-Based Method for Informed Source Separation of Audio Signals With a Single Sensor, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.6, pp.1464-1475, 2010. ,
DOI : 10.1109/TASL.2009.2035216
URL : https://hal.archives-ouvertes.fr/hal-00486809
Informed Source Separation of Linear Instantaneous Under-Determined Audio Mixtures by Source Index Embedding, IEEE Transactions on Audio, Speech, and Language Processing, vol.19, issue.6, pp.1721-1733, 2011. ,
DOI : 10.1109/TASL.2010.2097250
URL : https://hal.archives-ouvertes.fr/hal-00695763
Informed source separation through spectrogram coding and data embedding, Signal Processing, vol.92, issue.8, pp.1937-1949, 2012. ,
DOI : 10.1016/j.sigpro.2011.09.016
URL : https://hal.archives-ouvertes.fr/hal-00643957
Hybrid coding/indexing strategy for informed source separation of linear instantaneous under-determined audio mixtures, 20th International Congress on Acoustics, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00535684
Oracle estimators for the benchmarking of source separation algorithms, Signal Processing, vol.87, issue.8, pp.1933-1950, 2007. ,
DOI : 10.1016/j.sigpro.2007.01.016
URL : https://hal.archives-ouvertes.fr/inria-00545156
New Concepts in Parametric Coding of Spatial Audio: From SAC to SAOC, Multimedia and Expo, 2007 IEEE International Conference on, pp.1894-1897, 2007. ,
DOI : 10.1109/ICME.2007.4285045
Spatial audio object coding (SAOC) -The upcoming MPEG standard on parametric object based audio coding, 124th Audio Engineering Society Convention, 2008. ,
Spatial audio object coding with enhanced audio object separation, 13th International Conference on Digital Audio Effects (DAFx-10), 2010. ,
MPEG spatial audio object coding -The ISO/MPEG standard for efficient coding of interactive audio scenes, 129th Audio Engineering Society Convention, 2010. ,
High-fidelity multichannel audio coding with karhunen-loeve transform, IEEE Transactions on Speech and Audio Processing, vol.11, issue.4, pp.365-380, 2003. ,
DOI : 10.1109/TSA.2003.814375
Parametric multichannel audio coding: synthesis of coherence cues, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.1, pp.299-310, 2006. ,
DOI : 10.1109/TSA.2005.854105
Encoding Independent Sources in Spatially Squeezed Surround Audio Coding, 8th Pacific Rim Conference on Multimedia (PCM'07), pp.804-813, 2007. ,
DOI : 10.1007/978-3-540-77255-2_96
A Multichannel Sinusoidal Model Applied to Spot Microphone Signals for Immersive Audio, IEEE Transactions on Audio, Speech, and Language Processing, vol.17, issue.8, pp.1483-1497, 2009. ,
DOI : 10.1109/TASL.2009.2021716
Informed source separation: Source coding meets source separation, 2011 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.257-260, 2011. ,
DOI : 10.1109/ASPAA.2011.6082285
URL : https://hal.archives-ouvertes.fr/inria-00610526
Spatial codingbased informed source separation, EUSIPCO, 20th European Signal Processing Conference, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00869618
Object-based audio coding using nonnegative matrix factorization for the spectrogram representation, 128th Audio Engineering Society Convention, 2010. ,
Multichannel audio upmixing based on non-negative tensor factorization representation, 2011 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.33-36, 2011. ,
DOI : 10.1109/ASPAA.2011.6082296
Rate Distribution Between Model and Signal, 2007 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.243-246, 2007. ,
DOI : 10.1109/ASPAA.2007.4393033
On entropy-constrained vector quantization using gaussian mixture models, IEEE Transactions on Communications, vol.56, issue.12, pp.2094-2104, 2008. ,
DOI : 10.1109/TCOMM.2008.070357
A quantitative model of the ??????effective?????? signal processing in the auditory system. I. Model structure, The Journal of the Acoustical Society of America, vol.99, issue.6, pp.3615-3622, 1996. ,
DOI : 10.1121/1.414959
A Perceptual Model for Sinusoidal Audio Coding Based on Spectral Integration, EURASIP Journal on Advances in Signal Processing, vol.2005, issue.9, pp.1292-1304, 2005. ,
DOI : 10.1155/ASP.2005.1292
The Sensitivity Matrix: Using Advanced Auditory Models in Speech and Audio Processing, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.1, pp.310-319, 2007. ,
DOI : 10.1109/TASL.2006.876722
Source coding theory, 1990. ,
DOI : 10.1007/978-1-4613-1643-5
Nonnegative Matrix Factorization with the Itakura-Saito Divergence: With Application to Music Analysis, Neural Computation, vol.14, issue.3, pp.793-830, 2009. ,
DOI : 10.1016/j.sigpro.2007.01.024
Notes on Nonnegative Tensor Factorization of the Spectrogram for Audio Source Separation: Statistical Insights and Towards Self-Clustering of the Spatial Cues, 7th International Symposium on Computer Music Modeling and Retrieval, 2010. ,
DOI : 10.1007/978-3-642-23126-1_8
Speech coding based upon vector quantization, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.28, issue.5, pp.562-574, 1980. ,
DOI : 10.1109/TASSP.1980.1163445
Asymptotically Optimal Model Estimation for Quantization, IEEE Transactions on Communications, vol.59, issue.4, pp.1031-1042, 2011. ,
DOI : 10.1109/TCOMM.2011.012711.100405
URL : https://hal.archives-ouvertes.fr/inria-00553532
Informed Source Separation Using Latent Components, 9th International Conference on Latent Variable Analysis and Signal Separation (LVA/ICA'10), 2010. ,
DOI : 10.1007/978-3-642-15995-4_62
URL : https://hal.archives-ouvertes.fr/hal-00945298
Informed Source Separation Using Iterative Reconstruction, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.1, pp.178-185, 2013. ,
DOI : 10.1109/TASL.2012.2215597
Informed source separation: a comparative study, Proceedings European Signal Processing Conference, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00809525
Performance measurement in blind audio source separation, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.4, pp.1462-1469, 2006. ,
DOI : 10.1109/TSA.2005.858005
URL : https://hal.archives-ouvertes.fr/inria-00544230
PEMO-Q—A New Method for Objective Audio Quality Assessment Using a Model of Auditory Perception, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.6, pp.1902-1911, 2006. ,
DOI : 10.1109/TASL.2006.883259
Subjective and Objective Quality Assessment of Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.19, issue.7, pp.2046-2057, 2011. ,
DOI : 10.1109/TASL.2011.2109381
URL : https://hal.archives-ouvertes.fr/inria-00567152
Multichannel Nonnegative Matrix Factorization in Convolutive Mixtures for Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.3, pp.550-563, 2010. ,
DOI : 10.1109/TASL.2009.2031510
Distribution Preserving Quantization With Dithering and Transformation, IEEE Signal Processing Letters, vol.17, issue.12, pp.1014-1017, 2010. ,
DOI : 10.1109/LSP.2010.2087749
Linear mixing models for active listening of music productions in realistic studio condition, Proc. of the 132th Audio Engineering Society Conv, 2012. ,
Incremental subspace learning via non-negative matrix factorization, Pattern Recognition, vol.42, issue.5, pp.788-797, 2009. ,
DOI : 10.1016/j.patcog.2008.09.002
A General Framework for Online Audio Source Separation, International conference on Latent Variable Analysis and Signal Separation, 2012. ,
DOI : 10.1007/978-3-662-04619-7
URL : https://hal.archives-ouvertes.fr/hal-00655398
Context-Based Adaptive Arithmetic Encoding of EAVQ Indices, IEEE Transactions on Audio, Speech, and Language Processing, vol.20, issue.5, pp.1473-1481, 2012. ,
DOI : 10.1109/TASL.2011.2181834
Context-based adaptive binary arithmetic coding in the H.264/AVC video compression standard, IEEE Transactions on Circuits and Systems for Video Technology, vol.13, issue.7, pp.620-644, 2003. ,
DOI : 10.1109/TCSVT.2003.815173
