New interface
Journal articles
Perfectly Matched Layer with Mixed Spectral Elements for the Propagation of Linearized Water Waves
Gary Cohen 1 Sébastien Imperiale 2
1 POEMS - Propagation des Ondes : Étude Mathématique et Simulation
Inria Saclay - Ile de France, UMA - Unité de Mathématiques Appliquées, CNRS - Centre National de la Recherche Scientifique : UMR7231
2 M3DISIM - Mathematical and Mechanical Modeling with Data Interaction in Simulations for Medicine
LMS - Laboratoire de mécanique des solides, Inria Saclay - Ile de France
Abstract : After setting a mixed formulation for the propagation of linearized water waves problem, we define its spectral element approximation. Then, in order to take into account unbounded domains, we construct absorbing perfectly matched layer for the problem. We approximate these perfectly matched layer by mixed spectral elements and show their stability using the 'frozen coefficient' technique. Finally, numerical results will prove the efficiency of the perfectly matched layer compared to classical absorbing boundary conditions.
Document type :
Journal articles
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-00869627
Contributor : Sébastien Imperiale Connect in order to contact the contributor
Submitted on : Friday, October 4, 2013 - 3:00:48 PM
Last modification on : Tuesday, October 25, 2022 - 4:20:23 PM
Long-term archiving on: : Monday, January 6, 2014 - 10:06:44 AM
File
PML_WaterWaves.pdf
Identifiers
Citation
Gary Cohen, Sébastien Imperiale. Perfectly Matched Layer with Mixed Spectral Elements for the Propagation of Linearized Water Waves. Communications in Computational Physics, 2012, 11 (2), pp.285-302. ⟨10.4208/cicp.201109.261110s⟩. ⟨hal-00869627⟩
Share
Metrics
Record views
290
Files downloads
364
