json Scenario-Simple_XOR.json Scenario-Simple_XOR-proba-corpus.json Scenario-Simple_XOR-proba.json AmygdalaConfig_Simple-XOR-SimpleCortex.json CortexConfig_Simple-XOR-SimpleCortex.json For the Double XOR (sec. 3.3) we have Scenario-Double_XOR.json Scenario-Double_XOR-proba.json AmygdalaConfig-Double_XOR.json CortexConfig-Double_XOR.json And nally for the Double Mapped XOR and Double mapped crossed XOR (sec. 5.4, Scenario-Double_map.json Scenario-Double_map_crossed.json AmygdalaConfig_Double_map.json CortexConfig_Double_map.json Notice that the Splitted Amygdala uses only the behaviour constants for the Amygdalas and denes manually the sizes of its component Amygdalas based on the denition of the problem to solve ,
Émergence de catégories par interaction entre systèmes d'apprentissage, Conférence Francophone sur l'Apprentissage Automatique (CAP) ,
Conjunctive representations in learning and memory: Principles of cortical and hippocampal function., Psychological Review, vol.108, issue.2, pp.311-345, 2001. ,
DOI : 10.1037/0033-295X.108.2.311
The amygdala Current Biology, pp.868-874, 2007. ,
Why there are complementary learning systems in the hippocampus and neocortex: Insights from the successes and failures of connectionist models of learning and memory., Psychological Review, vol.102, issue.3, 1995. ,
DOI : 10.1037/0033-295X.102.3.419
Hebb-marr networks and the neurobiological representation of action in space, Neuroscience and Connectionist Theory, p.163 ,
A theory of pavlovian conditioning: Variations in the eectiveness of reinforcement and nonreinforcement. Classical Conditioning II : Current Research and Theory, p.6499, 1972. ,
Stimulus configuration, classical conditioning, and hippocampal function., Psychological Review, vol.99, issue.2, pp.268-305, 1992. ,
DOI : 10.1037/0033-295X.99.2.268
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.5397
Memory and the Hippocampus, Psychological Review, vol.99, 1992. ,
DOI : 10.1016/B978-0-12-148955-7.50016-3
Tree-like hierarchical associative memory structures, Neural Networks, vol.24, issue.2, p.143147, 2011. ,
DOI : 10.1016/j.neunet.2010.09.012
