On the significance of the geometric conservation law for flow computations on moving meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2000
The objective of this paper is to establish a firm theoretical basis for the enforcement of discrete geometric conservation laws (D-GCLs) while solving flow problems with moving meshes. The GCL condition governs the geometric parameters of a given numerical solution method, and requires that these be computed so that the numerical procedure reproduces exactly a constant solution. In this paper, we show that this requirement corresponds to a time-accuracy condition. More specifically, we prove that satisfying an appropriate D-GCL is a sufficient condition for a numerical scheme to be at least first-order time-accurate on moving meshes.
hal-00871722 , version 1 (10-10-2013)
Hervé Guillard, Charbel Farhat. On the significance of the geometric conservation law for flow computations on moving meshes. Computer Methods in Applied Mechanics and Engineering, 2000, 190 (11-12), pp.1467-1482. ⟨10.1016/S0045-7825(00)00173-0⟩. ⟨hal-00871722⟩
165 Consultations
0 Téléchargements
