Evolution and Evaluation of the Penalty Method for Alternative Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Computing meaningful alternative routes in a road network is a complex problem ― already giving a clear definition of a best alternative seems to be impossible. Still, multiple methods describe how to compute reasonable alternative routes, each according to their own quality criteria. Among these methods, the penalty method has received much less attention than the via-node or plateaux based approaches. A mayor cause for the lack of interest might be the unavailability of an efficient implementation. In this paper, we take a closer look at the penalty method and extend upon its ideas. We provide the first viable implementation ―suitable for interactive use― using dynamic runtime adjustments to perform up to multiple orders of magnitude faster queries than previous implementations. Using our new implementation, we thoroughly evaluate the penalty method for its flaws and benefits.
9.pdf (838.15 Ko) Télécharger le fichier
hal-00871738 , version 1 (10-10-2013)
Moritz Kobitzsch, Marcel Radermacher, Dennis Schieferdecker. Evolution and Evaluation of the Penalty Method for Alternative Graphs. ATMOS - 13th Workshop on Algorithmic Approaches for Transportation Modelling, Optimization, and Systems - 2013, Sep 2013, Sophia Antipolis, France. pp.94--107, ⟨10.4230/OASIcs.ATMOS.2013.94⟩. ⟨hal-00871738⟩
Collections
ATMOS2013
221 Consultations
556 Téléchargements
