Numerical simulation scheme of one-and two-dimensional neural fields involving space-dependent delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
Neural Fields describe the spatio-temporal dynamics of neural populations involving spatial axonal connections between neurons. These neuronal connections are delayed due to the finite axonal transmission speeds along the fibers inducing a distance-dependent delay between two spatial locations. The numerical simulation in 1-dimensional neural fields is numerically demanding but may be performed in a reasonable run time by implementing standard numerical techniques. However 2-dimensional neural fields demand a more sophisticated numerical technique to simulate solutions in a reasonable time. The work presented shows a recently developed numerical iteration scheme that allows to speed up standard implementations by a factor 10-20. Applications to some pattern forming systems illustrate the power of the technique.
article.pdf (209.29 Ko) Télécharger le fichier
hal-00872132 , version 1 (07-01-2014)
  • HAL Id : hal-00872132 , version 1
Axel Hutt, Nicolas P. Rougier. Numerical simulation scheme of one-and two-dimensional neural fields involving space-dependent delays. P. Beim Graben and S. Coombes and R. Potthast and J.J. Wright. Neural Field Theory, Springer, 2014. ⟨hal-00872132⟩
401 Consultations
365 Téléchargements
